" /> TServer integration with MQ Series and Domino - Genesys CTI User Forum
Author Topic: TServer integration with MQ Series and Domino  (Read 3633 times)
Brett
Has anyone had any experience integrating CTI functionality with back end mainframe systems via MQ Series?? I am also interested in how TServer may interface / intergrate with Lotus Domino? Brett
theresa
  • It will depend on what you mean by integration. If you are just trying to store some attached data then it should not be too hard. One of the byproducts of interaction router is customer server. It would serve as a gateway between Genesys and your application. What exactly are you trying to do? T.
