" /> ETL Re-aggregation (REP_REBUILD_LOG) - Genesys CTI User Forum
Author Topic: ETL Re-aggregation (REP_REBUILD_LOG)  (Read 3358 times)
Offline Adam_W
« on: November 05, 2008, 10:18:45 AM »
I had some problems with historical reporting this week and now I need to force ETL to re-aggregate some data.  At the moment, some reports are missing their daily stats, but if I run an hourly report the data is present.
In Datamart 7.1 you could run a simple statement to delete rows from REP_REBUILD_LOG from the date you require aggregation.  However, it looks like nothing has been written to this table since I upgraded to 7.2.
The data is definitely there so has the method of aggregation changed in 7.2?
Offline Adam_W
Re: ETL Re-aggregation (REP_REBUILD_LOG)
« Reply #1 on: November 05, 2008, 04:36:43 PM »
OK I found a script for 7.2 which should achieve my aim, however it's for an Oracle DBMS.  Long shot I know, but is anyone clever with both Oracle and SQL able to tell me how to achieve the same thing in SQL?!
whenever sqlerror exit failure
set serveroutput on
spool update
create or replace procedure EXECUTE_IMMEDIATE(cmd in varchar2) is
cur integer;
rc integer;
begin
cur := dbms_sql.open_cursor;
dbms_sql.parse(cur,cmd,dbms_sql.native);
rc := dbms_sql.execute(cur);
dbms_sql.close_cursor(cur);
exception
when others then
if dbms_sql.is_open(cur) then
end if;
raise;
end;
declare
cur integer;
vname varchar2(50);
aname varchar2(50);
tname varchar2(50);
rc integer;
begin
dbms_sql.parse(cur,
'select a.REP_VIEW_ID, a.PAR_AGG_COL_NAME, b.TABLE_NAME '||
'from REPORT_VIEW a, REP_TO_TAB c, REPORT_TABLE b '||
'where a.PAR_REP_VIEW_ID is not null '||
'and a.PAR_REP_VIEW_ID=c.REP_VIEW_ID '||
'and c.TABLE_ID=b.TABLE_ID '||
'and b.INFO_TYPE=''TIME_DIM'' '||
'and b.PHYSICAL_TYPE=''TABLE'' '||
'and a.PAR_AGG_COL_NAME=''AGG_BY_HOUR'' ',dbms_sql.native);
dbms_sql.define_column(cur, 1, vname, 50);
dbms_sql.define_column(cur, 2, aname, 50);
dbms_sql.define_column(cur, 3, tname, 50);
delete PENDING_AGG;
LOOP
IF dbms_sql.fetch_rows(cur) > 0 then
dbms_sql.column_value(cur, 1, vname);
dbms_sql.column_value(cur, 2, aname);
dbms_sql.column_value(cur, 3, tname);
EXECUTE_IMMEDIATE('insert into PENDING_AGG( REP_VIEW_ID, AGG_KEY, CNUMBER) select distinct '||vname||','||aname||', 0 '
||'from '||tname||' where to_char(END_TIME, ''YYYYMMDD'') >= ''yyyymmdd'' ');
ELSE
EXIT;
END IF;
END LOOP;
DBMS_OUTPUT.PUT_LINE('PENDING_AGG table updated');
commit;
end;
drop procedure EXECUTE_IMMEDIATE
