" /> QInfo / Status Tables - ConnID format - Genesys CTI User Forum
Author Topic: QInfo / Status Tables - ConnID format  (Read 4374 times)
Offline Adam_W
« on: March 03, 2009, 02:43:08 PM »
I notice that the ConnIDs which appear in the statserver tables are not in the same hexadecimal format as we see in the T Server logs / attached data.
Here is an example from my Status table: 38845362651778950
Is this correct or should I be using a different datatype for this column or something?  I'm using SQL 2005.
Is there any way to convert it?
Offline Timur Karimov
Re: QInfo / Status Tables - ConnID format
« Reply #1 on: March 03, 2009, 03:33:55 PM »
it's simple conversion from hex to dec. u can use MS T-SQL function "convert" for do it.
