" /> Access control for genesys reports - Genesys CTI User Forum
Author Topic: Access control for genesys reports  (Read 3784 times)
Offline gokulkumar.nair
« on: June 17, 2009, 09:23:21 AM »
Hello Everyone,
This is really urgent...can we control the access to reports generated in CC pulse+ according to the log in credentials of the users? Currently, we are creating workspaces for different agent groups and the views are controlled based on this.
I would like to know whether we can control the access, view, edit rights to a reports in CC pulse+ according to individual access rights rather than group access rights without having to create different workspaces for every individual ??
Thanks!!!
tony
Re: Access control for genesys reports
« Reply #1 on: June 17, 2009, 12:13:41 PM »
Perhaps you want to consider creating an instance of CCP+ which uses a local (C: Drive) path to the storage files (.STG's).  In this way, each User could have their own set of Views and Templates saved on their C: Drive, for when they log in...
Tony
tony
« Reply #2 on: June 17, 2009, 12:15:01 PM »
....in addition;
You could have a process to write/overwrite the Storage Files with new/updated Views and Template, using this method, too...
HTH?
Tony
tony
« Reply #3 on: June 17, 2009, 07:52:05 PM »
...not that "really urgent", then...  :-\
« Reply #4 on: June 17, 2009, 10:48:24 PM »
lol
