" /> Environment Control / Version / Compare - Genesys CTI User Forum
Author Topic: Environment Control / Version / Compare  (Read 3116 times)
Offline Scottyjohn
« on: November 23, 2009, 04:33:40 PM »
Hi guys,
Im looking at managing a large scale Genesys deployment, and am looking at a solution for managing the environments in terms of genesys configuration, app versions, harware/OS etc.  Also looking for a way to compare different environments for syncronisation purposes.  Ideally, ability to produce difference reports where we can home in on the things we need to address to achieve sync.
Any recommendations or experiences from you gus would be much appreciated :-)
tony
Re: Environment Control / Version / Compare
« Reply #1 on: November 23, 2009, 09:55:55 PM »
Not sure - try Jason at The Black Chair... Last I knew they were developing [i]Spotlight[/i], which is of and around Genesys configuration and such....
jason.owen@theblackchair.com
HTH?
Tony
Offline GenUser
« Reply #2 on: May 24, 2013, 11:41:14 AM »
check out http://www.auditgen.com/  and http://www.auditgen.com/en/technical-audit, you'll find out how easily you can compare application configuration between environments and highlights differences in Genesys familiar tabs and in your custom colours to track all discrepancies (added, modified or missing options)
« Reply #3 on: May 24, 2013, 12:31:09 PM »
I do not understand what you want. Genesys still has tools for management Genesys solution (from small to large) or you can write/develop your own app via PSDK for example. Do not reinvent wheel
