" /> OCM installation Error - Genesys CTI User Forum
Author Topic: OCM installation Error  (Read 3757 times)
Offline yahoo
  • yahoo
« on: April 08, 2010, 03:47:28 PM »
Hi All,
I have installed OCM on my laptop and when i try to open the OCM it gives me run time error
" no matching typelib is registered, or registered information is invalid"
pls let me know what does this mean by
phil
Re: OCM installation Error
« Reply #1 on: April 09, 2010, 12:38:31 PM »
hi there,
sorry, never seen this message before.
but it seems not to be a genesys-related error. maybe reinstallation of OCM solves the problem.
cheers
phil
Offline Pranpong.S
« Reply #2 on: April 12, 2010, 07:44:49 AM »
Hi All
      Which OS and OCM version using on your labtop.
Pranpong
[color=red]2009 GCP7-CIV Genesys Certified Professional 7[/color]
Offline bogdan
« Reply #3 on: April 13, 2010, 10:42:26 AM »
To install OCM I think you have a prerequsite, some wizards I think - I remember something about it before.
Bogdan
« Reply #4 on: April 13, 2010, 12:16:26 PM »
Is MDAC already installed? Are you installing with FULL admin rights? Which OS are you using?
Offline Dhanasekar
« Reply #5 on: June 14, 2010, 09:56:27 AM »
I have faced the same issue,As I have been working with OB from past four Years.
"no matching typelib is registered".
Install the StarterApp-Activex Tool kit on your machine and check you will be able to open without issue.
RCA is typelib are not registered properly.
