" /> Configuration Schema table tracking agent state login or logout - Genesys CTI User Forum
Author Topic: Configuration Schema table tracking agent state login or logout  (Read 2129 times)
Offline mduran22
Is anyone aware of a table in the config schema that keeps track of the agent state (i.e. if an agent is logged in or logged out)?
Mike
Offline Steve
Re: Configuration Schema table tracking agent state login or logout
« Reply #1 on: May 14, 2010, 03:41:59 PM »
Not in config directly.
But you could enable the login table in Stat Server, then point your DAP to the config database.
Steve
