" /> Abnormal termination of SIP Server application - Genesys CTI User Forum
Author Topic: Abnormal termination of SIP Server application  (Read 4827 times)
Offline sunbabu15
« on: January 14, 2011, 05:58:53 PM »
Hi All,
The SIP server application got stopped and while looking at the logs we saw the multiple occurrence of the below error  :
19:00:48.459 Std 02024 OS signal '0xC0000005' received
...exception in block [main]
----FAULT----01/12/11@19:00:48.4590----
Exception: 5 (0xc0000005) ACCESS_VIOLATION
AddrPC:    7d621079
AddrFrame: 016ccab4
AddrStack: 016cc9e4
This seems to memory leakage issue but not sure .
Can anyone please help me if you have encountered this type of error ?
Regards,
Offline Fra
Re: Abnormal termination of SIP Server application
« Reply #1 on: January 15, 2011, 09:32:46 PM »
which version? have you checked the relevant Release Notes?
Fra
Offline Timur Karimov
« Reply #2 on: January 17, 2011, 07:31:39 AM »
WIndows ? Did u have any anti-virus software instaled on it host?
WBR
Offline sunbabu15
« Reply #3 on: January 17, 2011, 06:08:32 PM »
Fra, I have verified the release notes and the application version is 7.6.001.17 .
Timur,We do have the McAfee Anti-virus installed on this host .
Regards,
Offline smile
« Reply #4 on: January 18, 2011, 07:36:38 AM »
[quote author=sunbabu15 link=topic=6110.msg26550#msg26550 date=1295287712]
Regards,
sunbabu15, such behavior can be a result of multiple factors. e.g. we got the same one because of special sequence tlib requests in customized desktop application. in our case this bug was documented in 7.6 and solved in version 8. i would recommend to you to put SR in support for such complex case.
« Last Edit: January 18, 2011, 10:57:26 AM by smile »
Offline sunbabu15
« Reply #5 on: January 18, 2011, 05:34:05 PM »
Thnx smile. Finally i have created a SR with Genesys support team for this.
« Reply #6 on: January 20, 2011, 10:30:58 AM »
Regards,
do next
1) remove mcafee from you sip server.
2) forget about any antivirus software on sip host
2) be happy
it's my own expirens and it can be different with official genesys recomendation.
WBR
Offline Fra
« Reply #7 on: January 20, 2011, 03:52:10 PM »
[quote author=Timur Karimov link=topic=6110.msg26588#msg26588 date=1295519458]
2) be happy
;D
