" /> Agent Invalid in URS log for Chat Session - Genesys CTI User Forum
Author Topic: Agent Invalid in URS log for Chat Session  (Read 3651 times)
Offline PFCCWA
« on: October 28, 2013, 12:05:49 PM »
We are trying to route chat sessions to agents (model set up) however when initiating the chat sample, it is not routing to the agent.
This is most likely to be a configuration issue so am trying to determine where and what is required.
I have an agent logged in.
The agent has a capacity rule ('default one media allows more than one interaction').
The agent has a login ID (that is set up in the multimedia switch agent logins folder.
I have a place (called Agent1Place), no DNs associated with it.
The place has a capacity rule (same one as agent).
The agent is logged in using the agent1place and with chat selected.
All applications are started and running with connections as per deployment and reference manual.
When the chat sample is initiated, nothing happens on the GAD side.
URS shows the agent as being invalid with interaction id error :
[i]received from 65214(MM81_IxnSrv)MMHost:6130(fd=) message EventPrivateInfo
AttributeExtensions [157] 00 01 03 00..
'Envelope3rdServer'(list) 'Parameters'(list) 'FaultCode' '100'
                                            'FaultString' 'interaction with specified id was not found'
                          'Service' 'Chat'
                          'Method' 'Message'
AttributeConnID 39f002367d7ae389
AttributeCustomerID 'Resources'
AttributeReferenceID 13460
AttributePrivateMsgID 5
11:35:30.141_T_I_39f002367d7ae389 [14:32] EventPrivateInfo is received for ts MM81_IxnSrv[Switch] (this dn=)
11:35:30.141_I_I_39f002367d7ae389 [09:05] >>>>>>>>>>>>resume interp(0), func:RequestService
    _I_E_39f002367d7ae389 [09:05] error in strategy: 0013 Remote error (RequestService)
11:35:30.141_I_I_39f002367d7ae389 [07:07] HERE IS TARGETS
TARGETS: Chat distribution for processing@.GA
    _M_I_39f002367d7ae389 [17:0f] VQ 0307b3f0 [at all 3 0 0] 1 Target(s), flag=940aa, guid: 0Resources||1|m38|1|00||||||01StatAgentsAvailable|00{}{}{}[]Chat distribution for processing@MM81_Statserver.GA
11:35:30.141_M_I_39f002367d7ae389 [13:01] current vq: 03076af8 id=5418(), nVQ=1-2f84310, priority=0, time=1382690536.0
11:35:30.141_M_I_39f002367d7ae389 [17:11] VQ 0307b3f0 first available call: 39f002367d7ae389, reason=(1)binding
11:35:30.141_M_I_39f002367d7ae389 [13:03] call (vq 03076af8, id=5418, priority 0, time 1382690536.0) waits for VQ 0307b3f0 (name="") now (0)
11:35:30.141_M_I_39f002367d7ae389 [17:0e] VQ 0307b3f0 (vq "", id=5418), (1 Targets): SELECT MAX by stat <StatAgentsAvailable>(random  00000000)
    _M_I_39f002367d7ae389 [17:0b] VQ 0307b3f0 TRG "Chat distribution for processing"(030edee8) #1, (3-2 Components): SELECT MAX by stat <StatAgentLoading>(random  0)
    _M_I_39f002367d7ae389 [10:0c] tenant Resources Agent agent1: dn chat (d 0) is ignored: other dn type(cfg)
    _M_I_39f002367d7ae389 [17:0b] VQ 0307b3f0 TRG "Chat distribution for processing"(030edee8) Cmp #1 agent1: not valid[/i]
Interaction server has similar error:
[i]1:35:29.997 Dbg 25020 Queuing dbmanager request: request id: '11740', request:[Bind:Update; update state = 2], stack:'default:standard', stack size: '8', interaction id:'0001Pa96J3QU0014'
11:35:29.997 Dbg 25032 Database request executed: DAP:'MM81_Ixn_DAP'(1), request id: '42073', dbchannel stack id: '3', interaction id:'', sql statement: [Commit Transaction]
11:35:29.997 Dbg 25021 Getting ready to send dbmanager request: request id: '11733', request:[update state = 2], stack size: '8', interaction id:'0001Aa95Y8MV0019'
11:35:29.997 Dbg 25030 Database request sent: DAP:'MM81_Ixn_DAP'(1), request id: '42078', dbchannel stack id: '1', interaction id:'', sql statement: [Begin Transaction]
11:35:29.997 Dbg 25032 Database request executed: DAP:'MM81_Ixn_DAP'(1), request id: '42078', dbchannel stack id: '1', interaction id:'', sql statement: [Begin Transaction]
11:35:29.997 Dbg 25030 Database request sent: DAP:'MM81_Ixn_DAP'(1), request id: '42079', dbchannel stack id: '2', interaction id:'0001Aa95Y8MV0019', sql statement: [execute binding (update state)]
11:35:29.997 Trc 26015 Received message 'ExternalServiceFault' ('502') from client 'MM81_ChatServer' - Third party server:0:1776, message attributes:
attr_envelope [list, size (unpacked)=324] =
  'Parameters' [list] = (size=80)
      'FaultCode' [str] = "100"
      'FaultString' [str] = "interaction with specified id was not found"
  'Service' [str] = "Chat"
  'Method' [str] = "Message"
attr_ref_id [int] = 357
11:35:29.997 Dbg 25032 Database request executed: DAP:'MM81_Ixn_DAP'(0), request id: '42074', dbchannel stack id: '3', interaction id:'', sql statement: [Commit Transaction]
11:35:29.997 Dbg 25021 Getting ready to send dbmanager request: request id: '11734', request:[update state = 2], stack size: '7', interaction id:'0001Aa95Y8MV001J'
11:35:29.997 Dbg 25030 Database request sent: DAP:'MM81_Ixn_DAP'(0), request id: '42080', dbchannel stack id: '1', interaction id:'', sql statement: [Begin Transaction]
11:35:29.997 Trc 24102 Sending to Universal Routing Server: urs: 'EventPrivateInfo' (150) message:
AttributePrivateMsgID [int] = 5 [XMSG_EVENT_3RD_SERVER_FAULT]
AttributeReferenceID [int] = 13460
AttributeCustomerID [str] = "Resources"
AttributeConnID [long] = 39f002367d7ae389
AttributeExtensions [list, size (unpacked)=159] =
  'Envelope3rdServer' [list] = (size=133)
11:35:29.997 Dbg 25032 Database request executed: DAP:'MM81_Ixn_DAP'(2), request id: '42075', dbchannel stack id: '3', interaction id:'', sql statement: [Commit Transaction]
11:35:29.997 Dbg 25021 Getting ready to send dbmanager request: request id: '11735', request:[update state = 2], stack size: '6', interaction id:'0001Aa95Y8MV001V'
11:35:29.997 Dbg 25030 Database request sent: DAP:'MM81_Ixn_DAP'(2), request id: '42081', dbchannel stack id: '1', interaction id:'', sql statement: [Begin Transaction]
11:35:29.997 Trc 26020 Distributing message 'EventExternalServiceResponded' ('194'), message attributes:
attr_extension [list, size (unpacked)=45] =
  'ReportingEventSequenceNumber' [str] = "38795496"
attr_actor_type [int] = 1 [STRATEGY]
attr_actor_tenant_id [int] = 101
attr_actor_strategy_id [str] = "Chat inbound strategy"
attr_actor_router_id [str] = "urs"
attr_event_time [str] = "2013-10-28T11:35:29Z"
attr_esp_client_refid [int] = 357
attr_esp_server_refid [int] = 13460
attr_esp_response_type [int] = 1
attr_esp_request_envelope [list, size (unpacked)=160] =
  'AppName' [str] = "MM81_ChatServer"
attr_esp_request_id [str] = "9N2LAJHJ5126H3R84OV3UTLECS0000B5"[/i]
is this something obvious I have missed?
thanks.[/list][/list][/list][/list]
Offline smile
Re: Agent Invalid in URS log for Chat Session
« Reply #1 on: October 28, 2013, 12:47:25 PM »
Hi
The message you found 'interaction with specified id was not found' most probably mean that you're trying to send text message from strategy and interaction server can't do this. If you got standard web chat sample strategy, most likely issue may be in web page where new interaction submitted.
As for agent distribution, agent login on mcr switch is not necessary. I found one significant "feature" in Genesys capacity model - web chat and voice im (sip) has identical media type number =5. Thus state of web chat channel is linked with voice/im channel. This bug is announced like "knowing issue" long time ago without any progress to resolve it. To check how it may involve on you environment:
1) delete agent login id from mcr switch
2) add agent login from sip switch (if exist)
3) add them voice channel and corresponding capacity rule
4) add voice dn on agent place
if this scheme will work, then you can cut unnecessary options from agent.
