" /> Cannot connect to datamart - Genesys CTI User Forum
Author Topic: Cannot connect to datamart  (Read 2709 times)
Offline MR_PT1
« on: April 22, 2014, 07:10:45 PM »
I'm trying to connect to datamart using jdbc. My costumer wants to use ssl encryption then they asked me two properties to insert in the jdbc url:
EncryptionMethod=SSL;ValidateServerCertificate=false
So I'm trying to connect but the SQL Server refuses the connection and logs indicate that "client doesn't supports encryption" and in the DataMart logs I only got "java.sql.SQLException I/O Error: DB server closed connection".
Someone knows if it works?
Offline MR_PT1
Re: Cannot connect to datamart
« Reply #1 on: April 24, 2014, 01:48:40 PM »
Just for your information:
Solved using ssl=require instead of EncryptionMethod=SSL;ValidateServerCertificate=false
Now, I must do the same to use ETL Assistant but I just don't know how...
