" /> Add multiple agent CME - Genesys CTI User Forum
Author Topic: Add multiple agent CME  (Read 2274 times)
Offline pmsylla
« on: October 15, 2015, 02:53:23 PM »
How can i add multiple agent in Configuration Manager ?
I tried to do it by the Config Database but if i do an Insert the base is locked.
Thanks all.
Offline Dionysis
Re: Add multiple agent CME
« Reply #1 on: October 15, 2015, 03:13:34 PM »
Editing the config database is often a very bad idea, you must interact with configuration via the supported interfaces.
It's been a while since using CME, but if I recall correctly, you need the Management Layer Wizard, which is a separate install.  With this installed you go to CME, right click on the persons folder, and find "Range of Agents" under the "Wizards" section.
Offline Tambo
« Reply #2 on: October 15, 2015, 03:29:05 PM »
you can use xml along with the wizard to do it
