" /> Executing Eclipse 'Generate All' from Composer from command line - Genesys CTI User Forum
Author Topic: Executing Eclipse 'Generate All' from Composer from command line  (Read 2920 times)
Offline prb75
I would like to be able to execute the 'Generate All' command from composer to produce the scxml and vxml artifcacts in src-gen using a continuous integration server like jenkins.  Does anyone have any tips for how to do this ?
Offline dbreeeze
Re: Executing Eclipse 'Generate All' from Composer from command line
« Reply #1 on: February 09, 2016, 06:25:18 PM »
You can generate all through eclipse's command line options and calling the composer command line application.
Just open the windows command prompt in the directory with eclipse and run something along the lines of:
[code]
eclipse.exe -nosplash -consoleLog -debug -data "C:\Users\<current user>\workspaces\composer\JavaComposerProject" -application com.genesyslab.composer.voice.generator.commandline.app
[/code]
Where -data is a full path to your eclipse workspace that has a composer project already imported.
