" /> Action codes for WDE application - Genesys CTI User Forum
Author Topic: Action codes for WDE application  (Read 2648 times)
Offline Dimitry
« on: December 15, 2016, 09:43:55 AM »
Hi ,
I have two WDE application used by different business lines. I want to apply a custom action code to only of the WDE application. How could I do that?
Currently the custom action codes created reflects to both WDE applications. I want it to be restricted only to one application.
Offline daniel_san
Re: Action codes for WDE application
« Reply #1 on: December 15, 2016, 02:28:03 PM »
You can create two custom views, and depending on wich application are the agent loged, show one or another.
Offline Dimitry
« Reply #2 on: December 16, 2016, 01:45:42 PM »
Do you mean by WDE customisation or is there any way to avoid control this WDE options in CME?
Offline daniel_san
« Reply #3 on: December 16, 2016, 01:56:45 PM »
I mean, with WDE Customization, you can do whatever you want.
But... if i´m not wrong... and if you want... You can modify the visible call results, and action codes. You can have two apps and modify call results to see by agent, and disposition codes.
