" /> What is the simplest way to find the stat server that is 'Primary' from composer - Genesys CTI User Forum
Author Topic: What is the simplest way to find the stat server that is 'Primary' from composer  (Read 2363 times)
Offline prb75
We have a warm stand-by backup in place but there are times during disaster recovery when the designation of stat servers changes from Primary to Backup.
So server A starts as primary and server B starts as backup,  but then after a restart server B becomes the primary.
How can I determine which stat server is primary ?  Is there some sort of operation from URS that can be used ?
Adam G
The option is in CIM/CME...
Offline prb75
thanks for your response, but I was hoping for some way to get this value from an ecma script variable or something so I could assmble a target on the fly like:
<pseudo code>
var primaryStatServer = something;
var target = 'myagentgroup@'+primaryStatServer;
Adam G
Thanks for the expansion/clarification.  Take a close look at your configuration - if you don't intend an auto-restart with a switchover/back to "Server B" as the Primary, there are options for that.  If you want to re-designate "Server B" as the Primary on failover, there are also options for that.
Otherwise, I think you might need to look at DNS failover solutions/options as opposed to "on the fly" config.  Products like "F5", "KEMP", etc. are a good place to start.
