" /> wan to disable personal call back option in workspace - Genesys CTI User Forum
Author Topic: wan to disable personal call back option in workspace  (Read 2526 times)
Offline vedgenesys
« on: January 20, 2017, 08:09:25 AM »
Hello friends,
I am new to genesys framework. There is a requirement of disabling a personal callback option from reschedule callback popup in IWS. please help me out from this.
Thanks in advance.
« Last Edit: January 23, 2017, 05:28:48 AM by vedgenesys »
Re: wan to disable personal call back option in workspace
« Reply #1 on: January 20, 2017, 01:51:20 PM »
If on IWS/WDE you will need to customize the application by coding on it. No setting will disable it by default.
You can disable whole reschedule tho:
https://docs.genesys.com/Documentation/IW/8.5.1/Dep/OutboundCampaignPrivileges
Offline vedgenesys
« Reply #2 on: January 23, 2017, 05:31:31 AM »
Thanks cavagnaro for your reply. It is in IWS. actually, I dont have access for the documents. expecting more info from you.... if you can ?
« Last Edit: January 23, 2017, 05:36:57 AM by vedgenesys »
« Reply #3 on: January 23, 2017, 10:35:59 AM »
From me? Like what?
Offline daniel_san
« Reply #4 on: January 27, 2017, 12:19:19 PM »
You can maybe use that option:
https://docs.genesys.com/Documentation/IW/8.5.1/Dep/OutboundOptions
outbound.callback-types
[Added: 8.5.115.17]
Default Value: personal,campaign
Valid Values: A comma separated list of callback types from the following list: personal, campaign
Changes take effect: At the next interaction
Description: Specifies whether an agent can select a personal callback or a campaign callback when rescheduling an Outbound campaign record, or whether all callbacks are either personal or campaign. This option can be overridden by a routing strategy, as described in Overriding Options by Using a Routing Strategy.
