" /> [SOLVED]Question on GAX 8.5 - Genesys CTI User Forum
Author Topic: [SOLVED]Question on GAX 8.5  (Read 3804 times)
Offline kny
« on: January 23, 2017, 01:03:50 PM »
I have a problem when starting GAX. I get the following error:
Cannot find method stopwinservice in class Gax Main.
Can anyone helo me on this?
« Last Edit: January 24, 2017, 11:20:53 AM by kny »
Re: Question on GAX 8.5
« Reply #1 on: January 23, 2017, 01:42:31 PM »
What version of GAAX are you using (and what version of JRE)? Try to post whole fragment of logs covering the issue.
Offline kny
« Reply #2 on: January 24, 2017, 10:51:26 AM »
GAX Version: 8.5.230.03]
JRE: 8u65
here is my log:
11:48:28: Starting logging to file ...
11:48:28: Current working folder=D:\Apps\SYGE\GCTI\gax
11:48:28: Starting application Java Server Starter. Version 8.1.000.02
11:48:28: Copyright (c) 2000-2011 Genesys Telecommunications Laboratories Inc.
11:48:28: Current date is 2017-01-24
11:48:28: Now will try to read the file D:\Apps\SYGE\GCTI\gax\JavaServerStarter.ini
11:48:28: Reading options from section [Service]
11:48:28: AppTitle=Genesys Administrator Extension
11:48:28: AppVersion=8.5.230.03
11:48:28: JVMPath=C:\java\Jr8\bin\server\jvm.dll
11:48:28: MainClass=GaxMain
11:48:28: EventHandlerMethod=stopWinService
11:48:28: Reading args from section [JavaArgs]:
11:48:28:  Warning: no args were found
11:48:28: Arg <-Djava.class.path> does NOT exists - will read section [Djava.class.path]:
11:48:28: gax.war
11:48:28: Adding -Djava.class.path=-Djava.class.path=;gax.war
11:48:28: Application is starting as Windows Service with name: GAX64
11:48:28: Reading application startup parameters:
11:48:28: -immediate
11:48:28: Setting service_synchronize_state = SCS_APP_STATUS_INITIALIZING
11:48:29: Loaded JVM library: C:\java\Jr8\bin\server\jvm.dll
11:48:29: Created JVM instance: jvm_args.version = JNI_VERSION_1_2, ignoreUnrecognized = TRUE
11:48:30: Setting ConsoleCtrlHandler processing...
11:48:30: ***************************************************
11:48:30: *****  JVM was delegated control - running  *****
11:48:31: Warning: Exception during CallStaticVoidMethod(main_jclass, main_mthd, app_arg)
11:48:31: Shutdown started, calling g_shutdown() ...
11:48:31: Starting application shutdown
11:48:31: Setting service_synchronize_state = SCS_APP_STATUS_STOP_PENDING
11:48:31: Shutdown running: Current thread was attached
11:48:31: Error: Cannot find method <stopWinService> in class: GaxMain
Offline kny
« Reply #3 on: January 24, 2017, 11:20:28 AM »
It works now I changed java versions.
