" /> Display pulse widget on Iframe - Genesys CTI User Forum
Author Topic: Display pulse widget on Iframe  (Read 2066 times)
Offline Amy
« on: February 07, 2017, 04:32:18 PM »
hello,
So, I am trying to display a dashboard widget on an iframe but i can't get the widget url .Any ideas  :) ?
Offline abudwill
Re: Display pulse widget on Iframe
« Reply #1 on: February 09, 2017, 05:05:46 PM »
I don't know much about Pulse - however, you could attempt to use a packet capture tool such as Wireshark and filter on HTTP protocol while going into GAX and opening areas of Pulse you need to see.  If it is not transported via SSL/TLS, you will likely able to see the URL that is being consumed.
« Reply #2 on: February 09, 2017, 06:41:30 PM »
Still would need to be logged in before that, not easy/default task.
