" /> IRD 7.5/URS 7.5: Which event should I use to simulate an answ./distr. call? - Genesys CTI User Forum
Author Topic: IRD 7.5/URS 7.5: Which event should I use to simulate an answ./distr. call?  (Read 2368 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi all.
As in subject, for a VQ; could be answered or distributed too.
Best regards, Gef.
« Last Edit: February 10, 2017, 02:40:08 PM by Gef Buneri »
Offline Tambo
sorry Gef do you mean EventRouteUsed ?
Offline Gef Buneri
Thanks for the interest, Tambo; I'm asking 'cause I don't know wich event to use to reach the goal.
Goal is to make an answered or distributed call  appear on a VQ, using a  - SendEvent["AN EVENT",Cat['ThisDN:',VQ]] - from IRD.
Are you suggesting to use EventRouteUsed as event type?
Offline Tambo
It's been a while Gef but i used (i'm sure)  SelectDN[Cat['VQ_',v_Department,'-',v_Skill]  to show a call routed to a VQ based upon subdepartment and skill VQ_UK-Sales
Offline Gef Buneri
The SelectDN would work for sure, but I was guessing if it exists another way, to avoid all the targeting process; just need to show a call on CCPulse. It is all fine for entered/abandoned/queued, but I failed to show an answered or distributed call.
Offline Tambo
you can see this in CCPUlse on a RP view for answered etc
Offline terry
May be just look at the EventDiverted distributed by USR in case of regular targeting routing and imitate it with SendEvent. Also such manual event sending always is risky - a lot of things might happen between sending EventWQueued and EventDiverted (error in strategy, call abandoning, etc) - there is risk to send first event but not send complimentary one.
Offline Gef Buneri
My goal is to count everything on a vq in order to have all data available on report db. The queue I'm using is not a real "target" queue, I'm using it just as a counter. In the specific case, I would like to count interactions that were managed by an automated IVR that does not ends on on agent, so I tought about to count the fully-completed-auto-processes as "answered", the total amount of call entered in the ivr as entered, and the abandoned-during-the-process as abandoned calls, on that vq. All fine for entered and abandoned, but I'm not able to show a fake answered/distributed, using events sent using "SendEvent".
***EDIT***
For the moment ClearTargets[] seems to work fine... it generates a cleared call on the desired vq, so the cleared calls, for that specific queue and CCPulse template, are considered as calls fullylly managed.
« Last Edit: February 13, 2017, 08:54:31 AM by Gef Buneri »
