" /> Missing URS requests in Log - Genesys CTI User Forum
Author Topic: Missing URS requests in Log  (Read 2979 times)
Offline kip1
« on: March 22, 2017, 12:18:41 PM »
Hi, when debugging with Kazimir I am missing URS requests in log such as RequestRouteCall. All I see is RequestSetCallInfo and RequestSetDNInfo. A little help? ??? ::)
Re: Missing URS requests in Log
« Reply #1 on: March 22, 2017, 12:23:45 PM »
Is the strategy on URS level executed at all? Try to post the log covering your problem.
Offline kip1
« Reply #2 on: March 22, 2017, 02:30:50 PM »
Yes, operational we are ok. But I can not recall which part of the log section in URS application is missing. As far as I remember it shouldn`t be in T-Server log section...
« Reply #3 on: March 22, 2017, 02:33:51 PM »
Do not understand the latest reaction from your site.
In general, check the "log" section on URS object whether it met your requirements for logging (verbose level, segment, etc.)
« Reply #4 on: March 22, 2017, 02:43:17 PM »
What is he trying to say? Kip we have no clue on what you are looking at on your logs, that is why you need to show us.
Hey guys, the thing that does that thing on the engine is missing... You have seen it out know how to fix it??
This is you right now
Offline vjicecool
« Reply #5 on: March 22, 2017, 07:04:19 PM »
[quote author=kip1 link=topic=10228.msg46422#msg46422 date=1490193050]
I am thinking you might have seen only half part of the log file not the full.
conn id's will be displayed in multiple log files.
so you need all log files from start to end to investigate
Offline terry
« Reply #6 on: March 23, 2017, 12:11:31 AM »
Sorry, just in case may be to check it is really URS logs.
Basically URS by itself never issues requests like RequestSetCallInfo and RequestSetDNInfo and they shouldn't be in URS log (if only not unlikely case that some strategy begins to issue them)
Offline kip1
« Reply #7 on: April 20, 2017, 07:20:50 AM »
[quote author=terry link=topic=10228.msg46431#msg46431 date=1490227891]
My bad. I was quoting T-Server logs. Nevertheless, after restarting T-Server it is ok.
