" /> ELK suite Genesys log - Genesys CTI User Forum
Author Topic: ELK suite Genesys log  (Read 5209 times)
Offline samir67000
« on: April 04, 2017, 01:34:39 PM »
Hello Everyone,
My name is samir and I am a trainee in a company in France. I have a project that aims to establish the ELK suite on the different logs produced by Genesys (URS, Tserver ...).
I wanted to know if you could help me because I have some difficulties.
Has anyone ever done this kind of project ? Please Tell me.
Thaaanks !
Offline Dionysis
Re: ELK suite Genesys log
« Reply #1 on: April 04, 2017, 01:52:01 PM »
Not sure there's many people who can help with "some difficulties", Is there a specific problem you're facing?
« Reply #2 on: April 04, 2017, 02:30:48 PM »
What kind of difficulties? Try to be more specific on that
Offline samir67000
« Reply #3 on: April 04, 2017, 02:37:34 PM »
Yes !
I explain my problem, This is my logstash configuration file :
https://cdn-enterprise.discourse.org/elastic/uploads/default/original/3X/5/5/554329891050f778def16c5fef4037671bb2f53b.png
And this is the content of the log :
https://cdn-enterprise.discourse.org/elastic/uploads/default/original/3X/5/9/595257a618954c0971d94c5904233b472141b464.png
As you have seen I work in mutiline. (Multiple lines in one document).
My goal is to extract only lines containing "#####".
I tried with the following filter : match => {"message" => "(?(?:^|\n).#####.(?:^\n|$))"}
But logstash sends me the whole document while I want only the line.
For example I want him to return :
https://cdn-enterprise.discourse.org/elastic/uploads/default/original/3X/7/f/7fdc3c4161d4cb1e2f3ba158dbfcaa9ad61aa9f8.png
But he return this :
https://cdn-enterprise.discourse.org/elastic/uploads/default/original/3X/a/8/a8622d1a370b8c69a3a6f1cd3e54a33d02270e5b.png
I hope you understand my problem and that you could help me.
Thanks so much !!!!!
« Reply #4 on: April 04, 2017, 03:12:15 PM »
The used regex seems to be wrong
Offline samir67000
« Reply #5 on: April 06, 2017, 07:48:46 AM »
Hello EveryOne,
I succeeded. Thank you very much.
I have just a last question, in the URS log, The structure is as follows :
[b]10:00:17.307[/b] Int 22000 ##### EI_COF_RCCAuto_v7 - 00f7029cddc0cf9f - RCCAUTO-0614304044- MAJ CFA suite
[b]10:00:17.307[/b]_I_I_00f7029cddc0cf9f [07:48] func will be continued(0,0000000030c000c6)
[b]10:00:17.307[/b]_M_I_00f7029cddc0cf9f [17:11] VQ 000000000478eca0 first available call: none, reason=(0)strategy
[b]10:00:17.307[/b]_I_I_00f7029cddc0cf9f [09:04] <<<<<<<<<<<<suspend interp(JUMPING), func:CallStrategy timers:00001
For each document I would like to extract the time and put it in a timestamp variable.
Can you help me ?
Offline PeteHoyle
« Reply #6 on: April 06, 2017, 09:26:09 AM »
Can you explain how you fixed your original issue...
For the timestamp would something like this work?
%{TIME:timestamp}
https://www.youtube.com/watch?v=YIKm6WUgFTY
https://grokdebug.herokuapp.com/
Offline samir67000
« Reply #7 on: April 06, 2017, 10:02:09 AM »
Yes I did this,
This sends me the time in a timestamp variable but I want it to send it into the @timestamp logstash. I did this but it does not work :
filter {
grok {
match => { "message" => "^%{TIME:timestamp}"}
date {
    match => [ "timestamp", "HH:mm:ss.SSS"]
target => "@timestamp"}
Offline samir67000
« Reply #8 on: April 06, 2017, 10:07:10 AM »
For my original issue I changed the grok filter  :
match => {"message" => "(?<diese>(?:^|\n).*#####.*(?:\n|$))"}
to  :
match => {"message" => "(?<diese>(?:^|\n)[^\n]*#####[^\n]*(?:\n|$))"}.
Offline PeteHoyle
« Reply #9 on: April 06, 2017, 05:29:09 PM »
This works for me..
[code]input
file {
    path => "C:\logs\InteractionWorkspace\TEST.txt"
start_position => "beginning"
    ignore_older => 0
filter {
    grok {
      match => ["message", "^%{TIME:timestamp}"]
date {
    match => [ "timestamp" , "HH:mm:ss.SSS" ]
locale => "en"
timezone => "UTC"
output
  stdout { codec => rubydebug }
  file {
                codec => line {
                        format => "%{[time]} | %{[severity]} : /%{[thread]}/ %{[loggername]} %{[timestamp]} (%{[sourcemethodname]}) %{[timestamp]} - %{[message]} PETE: %{[timestamp]}"
                path => "C:\logs\%{host}\PETE-%{+YYYY-MM-dd}.log"
}[/code]
Test.txt:
[code]10:00:18.307 Int 22000 ##### Did you see this one??
10:00:18.307 Int 22000 ##### Did you see this one???[/code]
Console Output:
[code]{
          "path" => "C:\\logs\\InteractionWorkspace\\TEST.txt",
    "@timestamp" => 2017-01-01T10:00:18.307Z,
      "@version" => "1",
          "host" => "xxxxx",
      "message" => "10:00:18.307 Int 22000 ##### Did you see this one??\r",
    "timestamp" => "10:00:18.307"
      "@version" => "1",
          "host" => "xxxxxx",
      "message" => "10:00:18.307 Int 22000 ##### Did you see this one???\r",
}[/code]
The date part of the @timestamp defaults to the first day of the year because there is no date in your log file timestamp.
Offline samir67000
« Reply #10 on: April 07, 2017, 07:53:46 AM »
Thank you very much it works !!
Yes, the date is false. The log date is in the header that looks like this :
[img]https://cdn-enterprise.discourse.org/elastic/uploads/default/original/3X/e/e/ee49b2d285121d5420f87a23abef706202df8b88.png[/img].
You think I can get the date highlighted and put it also in the timestamp to have the right date and the right time ?
Offline PeteHoyle
« Reply #11 on: April 07, 2017, 08:35:41 AM »
The short answer is I don't know.
If the log spans multiple days then that date will not be valid anyway.
It doesn't look like anyone is using Logstash with their Genesys logs on this forum, it might be best contacting Logstash to see if they can offer any help, but keep us informed if you find out how to do it.
Offline eugene
« Reply #12 on: April 09, 2017, 03:31:20 PM »
Peter, if you happen to work for Genesys please let the engineers know that we would love to see native application logging support to the Elastic stack.  I've been using ORS's capabilities for quite some time now and both for development or operational use has proven to be invaluable.
Offline jarrod
    • InProd CMS
« Reply #13 on: April 12, 2017, 11:41:57 AM »
So glad I found this post, we are looking at doing this as well.
Can not see Genesys adding this into the product and time soon.
Offline genesysguru
    • Genesys Guru Blog
« Reply #14 on: April 12, 2017, 03:34:57 PM »
Jarrod - also see http://www.sggu.com/smf/index.php/topic,10025.msg45471.html#msg45471
Craig
