" /> Unable to curl contact centre ID's - Genesys CTI User Forum
Author Topic: Unable to curl contact centre ID's  (Read 2172 times)
Offline outsourcedph
« on: June 15, 2017, 08:24:40 AM »
I am unable to connect to the contact center ID when I issue, this happened after I setup my RWS(HTTC)
curl -u ops:ops http://testlab:8080/api/v2/ops/contact-centers;echo
it either say's authentication failed(tried ressting password of ops tops on htpasswd) or is either unable to connect I would appreciate any immediate help.
Somebody gave me a recommendation to run ./nohup sudo gir start but I can't issue this command
I removed sudo since I use root but this command still fails
[root@testlab /]# ./nohup sudo gir start
bash: ./nohup: No such file or directory
[root@testlab /]# ./nohup gir start
[root@testlab /]# nohup gir start
nohup: ignoring input and appending output to `nohup.out'
nohup: failed to run command `gir': No such file or directory
Re: Unable to curl contact centre ID's
« Reply #1 on: June 15, 2017, 02:29:41 PM »
This is not related to "htpasswd"user, but this must be configured on IRWS (interaction recording web services) configuration file level
« Reply #2 on: June 15, 2017, 03:38:57 PM »
Hi Sir Kubig, it is configured on my Application.yaml settings below:
  # OPS account
  opsUserName: ops
  opsUserPassword: ops
I still cannot curl using ops user & password
« Reply #3 on: June 15, 2017, 06:12:02 PM »
Try this to start IRWS :
service gir start or /etc/init.d/gir start
