" /> there is no connections between Interaction Server and switches - Genesys CTI User Forum
Author Topic: there is no connections between Interaction Server and switches  (Read 2152 times)
Offline Peter Parker
Hi Expert,  ;D
I'm editing a scenario about email example in tab Business Process of IRD, while I active strategies (ABC Simple BP) there is an error have been occurred.
" There is no Interaction Server in your configuration. Or there is no connections between Interaction Server and switches.
Please run Configuration Server Manager and create Interaction Server and/or connection to media switch. then click Net button. "
I hope that everyone will help me explain detail about error as well as guide me step-by-step to configure it.  I have installed eService by manual on OS Windows, not installation it by Wizards.  ;)
Re: there is no connections between Interaction Server and switches
« Reply #1 on: June 17, 2017, 06:16:50 PM »
You have a switch for multimedia?
Follow documentation, there are all steps you need to do aside of the service installation
Offline terry
« Reply #2 on: June 17, 2017, 06:25:22 PM »
Check that tenant you work with
- is in tenant list of some URS
- is in tenant list of some Ixn server
- has Multimedia switch configured
« Reply #3 on: June 19, 2017, 12:55:01 PM »
Hi Cavagnaro, terry  ;D
I have been fixed it by modify configure as suggest of guys
Thanks for support me  ;D
