" /> Receives "SIP/2.0 404 Not Found" when run Predictive Outbound Campaign - Genesys CTI User Forum
Author Topic: Receives "SIP/2.0 404 Not Found" when run Predictive Outbound Campaign  (Read 3919 times)
Offline hieutx
Hi all, Please help me to fix this problem. I have implement ocs with GVP (GVP using floating IP Solution). When i run the predictive campaign. I got "System error" call result. I saw "'MediaServerErrorCode' 404" in sip logs. And Sip Server received "SIP/2.0 404 Not Found" . Below are ocs, sip, rm, logs.
ocs logs:
[code]11:42:10.918 Trc 50002 TEvent: EventDialing
11:42:10.918 OCSEvent[420]::EventDialing(Unknown,CallTypeOutbound)
TrTServer[108`hcmsip01]
DN[132`Environment]TrunkGroup
CallIpTMakeTransfer[108:19]::EventDialing {
CallProgressor[5:50000005]::EventDialing {
CallProgressor[5:50000005]::EventDialing{
FTCcall[108:19]::Created
FTCcall[108:19]::EventDialing
received from 65201(hcmsip01)hcmsip01:3000(fd=732) message EventReleased
AttributeCallState 4
AttributeCallType 3
AttributePropagatedCallType 3
AttributeCallID 16780218
AttributeConnID 006c02a4245a0002
AttributeCallUUID '1VAM2FAM6H4JFDPIEHGMATL00G000002'
AttributeUserData [736] 00 19 01 00..
'GSW_TZ_OFFSET' 25200
'GSW_PHONE' '00904716790'
'AccountBalance' '100'
'GSW_CALLING_LIST' 'Customer Care'
'GSW_CAMPAIGN_NAME' 'Customer Care Service'
'InteractionType' 'Outbound'
'InteractionSubtype' 'OutboundNew'
'GSW_RECORD_HANDLE' 5
'GSW_APPLICATION_ID' 162
'GSW_CAMPAIGN_GROUP_DBID' 106
'GSW_CALLING_LIST_DBID' 106
'GSW_SWITCH_DBID' 101
'GSW_CAMPAIGN_GROUP_NAME' 'Customer Care Service@ob_group'
'GSW_CAMPAIGN_GROUP_DESCRIPTION' ''
'GSW_CHAIN_ID' 1
'GSW_ATTEMPTS' 1
'GSW_AGENT_ID' ''
'GSW_CALL_RESULT' 28
'GSW_TZ_NAME' 'VST'
'GSW_CALL_ATTEMPT_GUID' 'CK3QEP6EM10DTARSEK00DEMV50000005'
'GSW_CONTACT_MEDIA_TYPE' 'voice'
'GSW_CALL_TYPE' 'REGULAR'
'GSW_QUEUE_DBID' 157
'GSW_SESSION_DBID' 106
[b]'MediaServerErrorCode' 404[/b]
AttributeDNIS '00904716790'
AttributeANI 'Environment'
AttributeCustomerID 'Environment'
AttributeThisDN 'Environment'
AttributeThisDNRole 1
AttributePartyUUID 'F2GV531V512KN3T9SKTUVN7GSS00000K'
AttributeOtherDN '00904716790'
AttributeOtherDNRole 2
AttributeExtensions [30] 00 01 00 00..
'OtherTrunkName' 'ANSV-Omni'
AttributeTimeinSecs 1497933730 (11:42:10)
AttributeTimeinuSecs 928000
AttributeEventSequenceNumber 0000000000000319
11:42:10.928 Trc 50002 TEvent: EventReleased
11:42:10.928 OCSEvent[421]::EventReleased(System Error,CallTypeOutbound)
CallIpTMakeTransfer[108:19]::EventReleased {
CallProgressor[5:50000005]::EventReleased {
CallProgressor[5:50000005]::EventReleased{
FTCcall[108:19]::EventReleased
[GOMessageType] EventGOSnapshotData
Attr GOLibAttrProtocolID [int]: 72AB62E3
Attr GOLibAttrReportData [TKVList]
0 ("Type"=12,"Val"=10,"CAGUID"="CK3QEP6EM10DTARSEK00DEMV50000005","ChGUID"="GKND3DA64L0RTBG6EGKALD0348000005","CSGUID"="NC205K2H3D10P1DUP2OOU9EIK8000005")
TotMet 1
SwID 101
ProvID 162
Attr GOLibAttrEventNum [long]: 44
Attr GOLibAttrTimestamp [long]: 1497933730928
option::log_call_stats = false {Application[162`outbound_contact_server]}
11:42:10.928 PAEventInfo (ContactInfo):
OwnerSessionDBID: 106; OriginSessionDBID: 106;
CallType:  PA_CallOutbound; StatType: PA_StatCallNoContact;
RecHandle: 5; CallID: 0;
PlaceDBID: 0; CallResult: 4;
11:42:10.928 PA Outbound Call Info:
OwnerDBID: 106; OriginDBID: 106; RecHandle: 5;
CurrentStatType: CallNoContact; State: OutCallNoContact; CPDCompletedFlag: 1; CompletedFlag: 1; CallResult: 4;
StatType Durations:
      CallDialed   0.01
      CallNoContact   0.00
Outbound Call deleted. RecHandle: 5; OwnerDBID: 106;
Call[5:50000005]::Applying treatment
11:42:10.928 Trc 50071 Send UserEvent
request to 65201(hcmsip01/hcmsip02) message RequestDistributeUserEvent
AttributeUserData [279] 00 0b 01 00..
'GSW_STAT_EVENT' 14
'GSW_CAMPAIGN_DBID' 105
'GSW_CALL_LIST_DBID' 106
'GSW_GROUP_DBID' 113
'GSW_AGENT_DBID' 0
'GSW_CALL_RESULT' 4
'GSW_CAMPAIGN_COMPLETE' 0
'GSW_LIST_COMPLETE' 0
'GSW_DIAL_MODE' 1
'GSW_SCHED_REC_NUM' 0
AttributeCommunicationDN 'Communication DN'
..sent to hcmsip01:3000(fd=732)
option::dial_log_destination = '' {CallingList[106`Customer Care] -> Application[162`outbound_contact_server]}
[GOMessageType] EventGOReportingData
EvtCode EventOCSChainProcessed
ProvID 162
SwID 101
GrpID 113
CmpID 105
LstID 106
ChID 1
CSGUID NC205K2H3D10P1DUP2OOU9EIK8000005
ChGUID GKND3DA64L0RTBG6EGKALD0348000005
Cause GOCauseChainCallResultReceived
CallGUID 1VAM2FAM6H4JFDPIEHGMATL00G000002
ClRes 4
DlrID 108
Attr GOLibAttrEventNum [long]: 45
RecTreatment - MaxAttempts exceeded  CallResult = 4
RecordHandle = 5  ChainID = 1 ChainNum = 0
Phone = 00904716790
PhoneType = 4
ListName = Customer Care  TableName = ob_balance
CampaignName = Customer Care Service
Attempt = 2
RecordType = 2
TZDBID = 111  TZOffset = 25200
DailyFrom = 0 (00:00:00)  DailyTill = 86340 (23:59:00)
Treatment = NULL
EvtCode EventOCSChainUnloaded
ProvID 162
SwID 101
GrpID 113
CmpID 105
LstID 106
ChID 1
Cause GOCauseChainMaxAttemptsReached
Attr GOLibAttrEventNum [long]: 46
UpdateRecord Handle:5 ChainID:1 ChainNum:0
11:42:10.928 CM_DBCallRecord(106-105-113): DBServer 'ocs_dbserver for Customer Care (740)' SQL:  update ob_balance set call_result=4,agent_id='',call_time=1497933730,record_type=2,record_status=3,attempt=2,switch_id=101  where chain_id=1 and chain_n=0 [ReqID=1091]
11:42:10.928 CM_DBCampaign:105 ProcessChain ChainID=1 GroupDBID:113 Records:1 Chains:0 OnTimer:0 AtWork:0
Call[5:50000005]::no treatment for the call result
11:42:10.928 Trc 50071 Send UserEvent[/code]
SIP Log:
[code]11:42:10.918: SipDialog: event SEND_INVITE, t=388, s=2, r=6, m=00000000029174c8
11:42:10.918: CID:CUUID>FE355A17-0B2C-4DA8-9D74-30E1B350269B-205@172.16.1.90:1VAM2FAM6H4JFDPIEHGMATL00G000002:
11:42:10.918 SIPCONN(Environment): HandleSipDialogEvent(SEND_INVITE) - filtered
11:42:10.918 SIPCONN(Environment): sdp state SDP_STATE_NULL, event SDP_EVENT_OFFER_REQUESTED
11:42:10.918 SIPCONN(Environment): new sdp state SDP_STATE_OFFER_REQUESTED, event SDP_EVENT_OFFER_REQUESTED
11:42:10.918 SIPCONN(Environment): state e:10,p:1,s:1,c:19,rc:0,m:1
11:42:10.918 SIPPARTY(Environment): 16779219 verify update of party-connection state I-I
11:42:10.918 --- CIFace::Request ---
11:42:10.918: $-TLIB:CTI:Unknown:0:2250
11:42:10.928: $+NET:SIP::0:0
[b]11:42:10.928: SIPTR: Received [0,UDP] 490 bytes from 172.16.1.13:5070 <<<<<
SIP/2.0 404 Not Found[/b]
Via: SIP/2.0/UDP 172.16.1.90:5060;branch=z9hG4bKABFE1DEC-6ED3-43E9-9814-77F055FA9D3D-36
From: <sip:00904716790@172.16.1.90:5060>;tag=A5CFEAB5-37B4-4890-BDE2-85AAF417847B-209
To: <sip:Environment@172.16.1.90:5060>;tag=4D10B9F3-964A-4726-1881-AD90809FB733
CSeq: 1 INVITE
Call-ID: FE355A17-0B2C-4DA8-9D74-30E1B350269B-205@172.16.1.90
Contact: sip:GVP@172.16.1.91:5070
Content-Length: 0
Warning: 399 172.16.1.93 "Matching IVR profile/tenant could not be found"
11:42:10.928: Sending  [0,UDP] 436 bytes to 172.16.1.91:5070 >>>>>
ACK sip:msml@172.16.1.91:5070;gvp-tenant-id=Enviroment SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
11:42:10.928: SipDialog: event CALLING_RESREJECT, t=388, s=9, r=5, m=00000000029174c8
11:42:10.928: CID:CUUID>FE355A17-0B2C-4DA8-9D74-30E1B350269B-205@172.16.1.90:1VAM2FAM6H4JFDPIEHGMATL00G000002:
11:42:10.928 SIPCONN(Environment): HandleSipDialogEvent(CALLING_RESREJECT)
11:42:10.928 SIPCONN(Environment): ConvertResponse: 404
11:42:10.928 SIPCONN(Environment): ConvertResponse: no conversion configured for 404
11:42:10.928 SIPCONN(Environment): operation 0, not deleted timer removed
11:42:10.928: failed to engage Media Server for predictive call
11:42:10.928 SIPCONN(Environment): CONNCHECK: dialog=9
11:42:10.928 SIPCONN(Environment): set monitor 0000000002917410, 0000000000000000
11:42:10.928 SIPCONN(Environment): Active transaction(388) discarded
11:42:10.928 SIPCONN(Environment): state e:1,p:1,s:0,c:19,rc:0,m:0
11:42:10.928: SipDialog: ClearCall(phone=0,state=9)
11:42:10.928: SipDialog::Terminate(state=9,reason=0)
11:42:10.928: SipDialog: set monitor 0000000000000000
11:42:10.928 SIPCONN(Environment): DetachMediaPeer
11:42:10.928: Adding OtherTrunkName(ANSV-Omni): done
@11:42:10.9280 [BSYNC] Trace: Send to backup (hcmsip02) [804]:
message RequestSetCallInfo
AttributeUpdateRevision 65644
'GSW_CHAIN_ID' 1
'GSW_ATTEMPTS' 1
'GSW_AGENT_ID' ''
'GSW_TZ_NAME' 'VST'
@11:42:10.9280 [BSYNC] Trace: Sent
11:42:10.928 ClearContext: party Environment.2917c40-2b3a060:1[/code]
RM log:
[code]2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:948 221439664 ProcessTimerEvent
2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:962 221439664 ProcessTimerEvent: SEND HB m_nSeqNum=2025
2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 08500000 VGNICLinkDetection.C:327 Entry 12 is up
2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1023 221439664 ProcessTimerEvent: m_nTotalNodes=1 bNetworkUp=1
2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1101 221439664 ProcessTimerEvent: Server 2
2017-06-20 11:42:09.473 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1108 2 ProcessTimerEvent:m_nClientSocketState=3 m_nClientSocket=281200016 m_nServerSocketState=3 m_nServerSocket=380644512 m_bFailureReported=1
2017-06-20 11:42:09.865 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:859 221439664 VGSocketData nSocket=380644512
2017-06-20 11:42:09.865 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:906 221439664 VGSocketData HB RX nSocket=380644512 newNum=5278
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:948 221439664 ProcessTimerEvent
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:962 221439664 ProcessTimerEvent: SEND HB m_nSeqNum=2026
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 08500000 VGNICLinkDetection.C:327 Entry 12 is up
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1023 221439664 ProcessTimerEvent: m_nTotalNodes=1 bNetworkUp=1
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1054 221439664 ProcessTimerEvent: HB Check on Server 2 (RMCOMMREDUNDANT) m_nOldSeqNum=5276 m_nNewSeqNum=5278
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1101 221439664 ProcessTimerEvent: Server 2
2017-06-20 11:42:11.475 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1108 2 ProcessTimerEvent:m_nClientSocketState=3 m_nClientSocket=281200016 m_nServerSocketState=3 m_nServerSocket=380644512 m_bFailureReported=1
2017-06-20 11:42:11.865 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:859 221439664 VGSocketData nSocket=380644512
2017-06-20 11:42:11.865 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:906 221439664 VGSocketData HB RX nSocket=380644512 newNum=5279
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:948 221439664 ProcessTimerEvent
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:962 221439664 ProcessTimerEvent: SEND HB m_nSeqNum=2027
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 08500000 VGNICLinkDetection.C:327 Entry 12 is up
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1023 221439664 ProcessTimerEvent: m_nTotalNodes=1 bNetworkUp=1
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1101 221439664 ProcessTimerEvent: Server 2
2017-06-20 11:42:13.476 DBUG 00000000-00000000 3224 09500901 RMCommTCPBonding.cxx:1108 2 ProcessTimerEvent:m_nClientSocketState=3 m_nClientSocket=281200016 m_nServerSocketState=3 m_nServerSocket=380644512 m_bFailureReported=1
2017-06-20 11:42:13.866 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:859 221439664 VGSocketData nSocket=380644512
2017-06-20 11:42:13.866 DBUG 00000000-00000000 3220 09500901 RMCommTCPBonding.cxx:906 221439664 VGSocketData HB RX nSocket=380644512 newNum=5280
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:674 configNotificationCallback >> Received Cfg notification event type [5]. Callback stacksize [0]
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:849 utilProcessDeltaObject >> Entered CFGApplication.
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1629 processDeltaApplication >> Entered.
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1667 processDeltaApplication >> CFGObjectChanged
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1676 processDeltaApplication >> App.DBID=133
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2013 processOptionsAnnexData >> Getting [options/CFGOptions] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2079 utilProcessAppProperty >> contains data.
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2016 processOptionsAnnexData >> Getting [annex/CFGUserProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2019 processOptionsAnnexData >> Getting [annex/CFGFlexibleProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2026 processOptionsAnnexData >> Getting [Changed options/CFGChangedOptions] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2029 processOptionsAnnexData >> Getting [Changed annex/CFGChangedUserProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2032 processOptionsAnnexData >> Getting [Changed annex/CFGChangedFlexibleProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2045 processOptionsAnnexData >> Getting [deleted options/CFGDeletedOptions] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2048 processOptionsAnnexData >> Getting [deleted annex/CFGDeletedUserProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:2051 processOptionsAnnexData >> Getting [deleted annex/CFGDeletedFlexibleProperties] reference...
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1747 processDeltaApplication >> All handlers processed. Normal exit.
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1120 checkForClientNotification >> object KEY=1_9_133
2017-06-20 11:42:14.024 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:1172 checkForClientNotification >> Callback
2017-06-20T11:42:14.024 Std 20141 NOTE 00000000-00000000 2548 0940040B updateNotification()
2017-06-20 11:42:14.026 DBUG 00000000-00000000 2548 08500000 CCIMFConfigImpl.cpp:3855 utilSearchCfgObjects >> ConfGetObjectInfo fi[/code]
MCP log:
[code]2017-06-20T11:42:10.568 Trc 33009 INFO 00000000-00000000 3496 02800FA1 Request received: OPTIONS sip:172.16.1.12:5090 SIP/2.0
Via: SIP/2.0/UDP 172.16.1.93:5064;branch=z9hG4bK000000001D60C27048a7a1
From: <sip:GVP@172.16.1.93:5064>;tag=DCC347D7-CBA5-46C7-7D90-F875349B2C03
To: sip:172.16.1.12:5090
Max-Forwards: 70
CSeq: 40489 OPTIONS
Call-ID: 75861782-BA0F-42ED-9E85-C269A0733BDA-5064@172.16.1.93
Contact: <sip:GVP@172.16.1.93:5064>
Content-Length: 0
Supported: timer, uui
2017-06-20 11:42:10.568 DBUG  3496 08500000 MPCSDPNegotiation.cxx:561 SDPNegotiation::NegotiateSDP - nSDPOfferAns=[0], bRemotePref=[true]
2017-06-20 11:42:10.568 DBUG  3496 08500000 MPCSDPNegotiation.cxx:594 Generating brand new SDP offer
2017-06-20 11:42:10.568 DBUG 00000000-00000000 3496 08500000 VGRTPTypes.cxx:1716 RTPMediaDescListToVGSdp
2017-06-20 11:42:10.568 DBUG 00000000-00000000 3496 08500000 VGSIPTransportMgr.cxx:3474 VGSIPTransportMgr::ResolveDNS for 172.16.1.13:5064
2017-06-20 11:42:10.568 DBUG 00000000-00000000 3496 08500000 VGSIPTransportMgr.cxx:3585 VGSIPTransportMgr::ResolveDNS nResult 2
2017-06-20T11:42:10.568 Trc 33009 INFO 00000000-00000000 3496 02800FA1 Response sent: SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.16.1.93:5064;branch=z9hG4bK000000001D60C27048a7a1;received=172.16.1.13
CSeq: 40489 OPTIONS
Content-Length: 1516
Content-Type: application/sdp
v=0
o=- 268442479 1 IN IP4 172.16.1.92
s=phone-call
c=IN IP4 172.16.1.92
t=0 0
m=audio 0 RTP/AVP 0 8 9 2 18 3 105 106 112 113 101
a=rtpmap:0 pcmu/8000
a=rtpmap:8 pcma/8000
a=rtpmap:9 g722/8000
a=rtpmap:2 g726-32/8000
a=rtpmap:18 g729/8000
a=rtpmap:3 gsm/8000
a=rtpmap:105 AMR/8000
a=fmtp:105 octet-align=0
a=rtpmap:106 AMR/8000
a=fmtp:106 octet-align=1
a=rtpmap:112 AMR-WB/16000
a=fmtp:112 octet-align=0
a=rtpmap:113 AMR-WB/16000
a=fmtp:113 octet-align=1
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 0 RTP/AVP 34 99 100 113 114 115 116 117 118 120
a=rtpmap:34 h263/90000
a=fmtp:34 profile=0;level=70
a=rtpmap:99 h263-1998/90000
a=fmtp:99 profile=0;level=70
a=rtpmap:100 h263-1998/90000
a=fmtp:100 profile=0;level=70;F=1;I=1;J=1;T=1;P=1
a=rtpmap:113 h264/90000
a=fmtp:113 profile-level-id=42001F; packetization-mode=0; use-level-src-parameter-sets=0
a=rtpmap:114 h264/90000
a=fmtp:114 profile-level-id=42001F; packetization-mode=1; use-level-src-parameter-sets=0
a=rtpmap:115 h264/90000
a=fmtp:115 profile-level-id=42401F; packetization-mode=0; use-level-src-parameter-sets=0
a=rtpmap:116 h264/90000
a=fmtp:116 profile-level-id=42401F; packetization-mode=1; use-level-src-parameter-sets=0
a=rtpmap:117 h264/90000
a=fmtp:117 profile-level-id=4D001F; packetization-mode=0; use-level-src-parameter-sets=0
a=rtpmap:118 h264/90000
a=fmtp:118 profile-level-id=4D001F; packetization-mode=1; use-level-src-parameter-sets=0
a=rtpmap:120 vp8/90000
a=sendrecv
2017-06-20T11:42:11.580 Trc 33009 INFO 00000000-00000000 3496 02800FA1 Request received: OPTIONS sip:172.16.1.12:5090 SIP/2.0
Via: SIP/2.0/UDP 172.16.1.93:5064;branch=z9hG4bK000000001D609B4048a7a2
From: <sip:GVP@172.16.1.93:5064>;tag=A213F312-ED4C-421A-9580-735FD6E47CCF
Max-Forwards: 70
CSeq: 40492 OPTIONS
Call-ID: D5012B1A-C61A-438E-25AC-8D3E2F22836D-5064@172.16.1.93
Content-Length: 0
[/code]
Offline Fra
You have not configured properly the GVP IVR Profile.
GVP returns "Matching IVR profile/tenant could not be found".
Offline hsujdik
Perhaps you should create a "Default IVR Profile" for your tenant. Read the chapter "Configuring GVP Components 3", section "Assigning Default Tenants and Creating Default Profiles" from the "GVP Deployment Guide" documentation (link below).
https://docs.genesys.com/Documentation/GVP/85/GDG/CG3#ADTCDP
