" /> Add UUI to call transfer - Genesys CTI User Forum
Author Topic: Add UUI to call transfer  (Read 2949 times)
Offline masgar
« on: June 26, 2017, 01:28:05 PM »
I need to make a blind transfer from an IRD strategy, but before transfer the call I need to add the Sip UUI header.
My test strategy is a simple multi function block with:
Update['UU_DATA','1234567890abcdef;encoding=hex;purpose=isdn-network;content=isnd-uui']
TRoute['3211','',RouteTypeUnknown,'']
The call transfer is OK but on destination PBX I don't see the UUI (checked with a wireshark trace).
Anyone can point me in the right direction?
Max
« Last Edit: June 26, 2017, 01:46:57 PM by masgar »
Offline jamesmurphyau
Re: Add UUI to call transfer
« Reply #1 on: June 26, 2017, 09:56:25 PM »
You can do it two ways:
1. Configure SIP server options that map 'UU_DATA' to the 'User-to-User' header
2. Use AttributeExtensions to attach the header and instruct SIP server to include it in the SIP message
Using method two, the example would be:
ExtensionUpdate['SIP_HEADERS', 'User-to-User']
ExtensionUpdate['User-to-User', '<user to user value>']
Offline masgar
« Reply #2 on: June 27, 2017, 01:42:29 PM »
Thank you very much. It worked.
Max
