" /> Sip T-server -> RM -> MCP - Genesys CTI User Forum
Author Topic: Sip T-server -> RM -> MCP  (Read 3762 times)
Offline vjicecool
« on: June 26, 2017, 04:04:02 PM »
what is the good way to understand the Sip events between all three applications
3 way Sip communication is little confusing to me.
any help would be appreciated
Re: Sip T-server -> RM -> MCP
« Reply #1 on: June 26, 2017, 04:45:21 PM »
Good way...tricky...not easy definitively...just sit down, study each scenario and follow the SIP messages exchange.
Basically SIP Server sends requests to RM and RM to MCP.
Offline vjicecool
« Reply #2 on: June 27, 2017, 07:26:49 PM »
[quote author=cavagnaro link=topic=10447.msg47422#msg47422 date=1498495521]
Thank you for the response and a question
does the call id generated in sip t-server for a call will remain same in RM and MCP or it will be different for each app?
« Reply #3 on: June 27, 2017, 07:29:02 PM »
Call ID is an ID for that call, will be valid until the call exists SIP Server.
Offline n3vek7
    • ITKB
« Reply #4 on: June 28, 2017, 02:18:30 AM »
ConnId is generated by TSrv/SIPSrv,
GUID/UUID is generated by RM.
There's multiple unique key, but those two are the main one for me.
Offline vjicecool
« Reply #5 on: June 28, 2017, 05:56:46 PM »
I would like to trace/troubleshoot a call
so In sip t-server i need to look for call-id and then in rm GUID and in MCP another call/guid?
is this how you usually trouble shoot or any other tool available?
« Reply #6 on: June 28, 2017, 06:11:58 PM »
I use connid, the ANI and time of call
CallID can help too but I am not quite a fan of it
Offline Fra
« Reply #7 on: June 29, 2017, 07:40:14 AM »
[quote author=vjicecool link=topic=10447.msg47465#msg47465 date=1498672606]
If you're looking into troubleshooting SIP to GVP , I find it best through the Call-ID, as that is what is used by SIP.
ConnID for everything else.
