" /> Dial plan for SIP Server - Genesys CTI User Forum
Author Topic: Dial plan for SIP Server  (Read 1742 times)
Offline sergioperez
« on: August 02, 2017, 09:57:10 PM »
Hello to all,
I am trying to establish a dial plan, so the agent of the team communicator dial a number, but automatically the SIP Server dial another number. Can you please help me to create the dial plan?.
1587465 + cellphone + 123456
The agent should only dial the cellphone.
I appreciate your help with this.
Re: Dial plan for SIP Server
« Reply #1 on: August 03, 2017, 12:46:40 PM »
From SIP Server guide:
[code]Sample Dial Plan Rules
Some sample values for the dial-plan-rule-<n> option, configured in the dialplan DN, are as follows:
5XXX=>4351707${DIGITS} # This rule matches any 4-digit number
starting with 5 and translates it to the number 43517075XXX
5002=>43517075002 # This rule matches the dialed number 5002 and
translates it to the number 43517075002 [/code]
Almost what you need, so check it and apply. Documentation is your friend
