" /> What is the URL for EWT ? - Genesys CTI User Forum
Author Topic: What is the URL for EWT ?  (Read 2580 times)
Offline absolute karma
« on: August 06, 2017, 08:34:06 PM »
I have a requirement in which I need to play EWT to a caller ? I am using composer workflow. I have heard that there is an API for this. How do I use it to play EWT? What are the parameters I need to pass in the URL?
Re: What is the URL for EWT ?
« Reply #1 on: August 07, 2017, 02:51:10 AM »
No API, you need to use a statistic to get that info.
Search the forum
Offline jamesmurphyau
« Reply #2 on: August 07, 2017, 05:11:26 AM »
There actually is an API - the URS web server that you can access from IRD with ‘RequestRouter’
« Reply #3 on: August 07, 2017, 08:23:40 PM »
From CallBack (GM) Guide:
[quote]Query URS
To retrieve the Expected Waiting Time (EWT) for callback, you can use the lvq method of the URS Web API and directly query the following URS URL:
http://<urshost>:<ursport>/urs/call/max/lvq?name=VQ_Name&aqt=urs&tenant=TenantName
To view additional URS lvq input parameters and output information, open a browser with URS running and run the help method for lvq as follows:
http://<urshost>:<ursport>/urs/help/call/lvq
The help method is described in the Universal Routing 8.1 Reference Manual, Appendix C, "Supported Methods."
But there requirements like URS version and what type of VQ
URL:
https://docs.genesys.com/Documentation/CLBCK/8.5.1/UG/GetEWT
« Last Edit: August 07, 2017, 08:25:34 PM by cavagnaro »
Offline morad
« Reply #4 on: August 08, 2017, 10:16:08 PM »
He is using Composer, so no need for API. Just use a statistic to get EWT as Cavagnaro sugessed
Sent from my LG-H812 using Tapatalk
« Reply #5 on: August 09, 2017, 12:54:10 AM »
?? Composer doesn't has nothing to do...it is just a client
As for the API is latest URS HTTP who provides it, the server, client could be Composer or any other
