" /> Er_ORS_Tomcat Application terminated due to internal condition - Genesys CTI User Forum
Author Topic: Er_ORS_Tomcat Application terminated due to internal condition  (Read 1912 times)
Offline C_Genesys
We are getting below alarm
Er_ORS_Tomcat_N11, Application terminated due to internal condition
If we check on the machine we see that this application is running fine since last 25 days.
If we check the LCA logs on on this host we see the below:
04:02:44  Found(1) PID=14384 for ThirdPartyApp{887,'Er_ORS_Tomcat_N11',cmdline='/bin/ksh /appl/genesys/tomcat/bin/tomcat.sh '}
04:02:44 CREATE Application <887, Er_ORS_Tomcat_N11, pid=14384, socket=-1, confserv=:>.
04:02:44 Notify STATUS: App<887, Er_ORS_Tomcat_N11, pid=14384, APP_STATUS_RUNNING, PRIMARY.
04:02:44 ~ThirdPartyApp<887, Er_ORS_Tomcat_N11>
04:02:45 #### OS Level STOPPED: App<887, Er_ORS_Tomcat_N11, pid=14384>
04:02:45 Notify STATUS: App<887, Er_ORS_Tomcat_N11, pid=14384, APP_STATUS_STOPPED, PRIMARY.
04:02:45 CREATE ThirdPartyApp <887, Er_ORS_Tomcat_N11, confserv=:>.
04:02:45 ~Application<14384, Er_ORS_Tomcat_N11>
04:02:45 Ml_SoCoSrv_N11: 04:02:45 [RequestAppStatus] on App 'Er_ORS_Tomcat_N11' <pid=14384, dbid=887>
04:02:45 Found by AppID=887
04:02:45 Notify STATUS: App<887, Er_ORS_Tomcat_N11, pid=26393, APP_STATUS_RUNNING, PRIMARY.
04:02:45 Ml_SoCoSrv_Z11: 04:02:45 [RequestAppStatus] on App 'Er_ORS_Tomcat_N11' <pid=14384, dbid=887>
04:02:45 Ml_SoCoSrv_Z11: 04:02:45 [RequestAppStartupInfoChanged] on App 'Er_ORS_Tomcat_N11' <pid=26393, dbid=887>
04:02:45 Ml_SoCoSrv_Z11: 04:02:45 [RequestAppHangupConf] for App 'Er_ORS_Tomcat_N11' <pid=26393, dbid=887>
04:02:45 Hangup detection is not enabled
04:02:54  Found(1) PID=26393 for ThirdPartyApp{887,'Er_ORS_Tomcat_N11',cmdline='/bin/ksh /appl/genesys/tomcat/bin/tomcat.sh '}
[u][b][b]If we see SCS logs[/b][/b][/u]
04:02:44.367 XXXXXX: REventAppLiveStatusChanged... APP_STATUS_RUNNING, mode=PRIMARY, app=Er_ORS_Tomcat_N11, PID=14384
04:02:44.394 04:02:44.394 [gsnmpalib]: Received MEvent (Successful,0,0) from managed server 'Hr_StatSrv_Z11' dbid = 105 sd = 65.
04:02:45.154  Trace  XXXXXXX.xx.xxxx.com  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] AgentXSlave: sending notify PDU (trap): (1.3.6.1.6.3.1.1.4.1.0)
04:02:45.154 ### LOCAL MESSAGE#=30201, '[Agent++] AgentXSlave: sending notify PDU (trap): (1.3.6.1.6.3.1.1.4.1.0)'
04:02:45.154  Trace  XXX.xx.xxxx.com  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] AgentX: sending agentx pdu (sd)(type)(sid)(tid)(pid)(err)(errind): (49), (12), (1), (1298911), (2378546), (0), (0)
04:02:45.154 ### LOCAL MESSAGE#=30201, '[Agent++] AgentX: sending agentx pdu (sd)(type)(sid)(tid)(pid)(err)(errind): (49), (12), (1), (1298911), (2378546), (0), (0)'
04:02:45.154  Trace  XXXXXX.xx.xxxx.com  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] AgentX: sending agentx pdu (sd)(type)(sid)(tid)(pid)(err)(errind): (49), (13), (1), (1298912), (2378548), (0), (0)
04:02:45.154 ### LOCAL MESSAGE#=30201, '[Agent++] AgentX: sending agentx pdu (sd)(type)(sid)(tid)(pid)(err)(errind): (49), (13), (1), (1298912), (2378548), (0), (0)'
[Agent++] AgentXSlave: received something on ports
04:02:45.155 ### LOCAL MESSAGE#=30202, '[Agent++] AgentXSlave: received something on ports'
04:02:45.155  Trace  XXXXX.xx.xxxx.com  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] AgentXRequestList: request received (context)(tid)(pid)(siz)(type)(err)(status): (), (1298911), (2378546), (2), (18), (0), (0)
04:02:45.155 ### LOCAL MESSAGE#=30201, '[Agent++] AgentXRequestList: request received (context)(tid)(pid)(siz)(type)(err)(status): (), (1298911), (2378546), (2), (18), (0), (0)'
[Agent++] SubAgentXMib: unhandled response (tid)(pid): (1298911), (2378546)
04:02:45.156 ### LOCAL MESSAGE#=30202, '[Agent++] SubAgentXMib: unhandled response (tid)(pid): (1298911), (2378546)'
04:02:45.156 ### LOCAL MESSAGE#=30202, '[Agent++] AgentXSlave: received something on ports'
04:02:45.156  Trace  XXXXXXX.xx.xxx.com  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] AgentXRequestList: request received (context)(tid)(pid)(siz)(type)(err)(status): (), (1298912), (2378548), (0), (18), (0), (0)
04:02:45.156 ### LOCAL MESSAGE#=30201, '[Agent++] AgentXRequestList: request received (context)(tid)(pid)(siz)(type)(err)(status): (), (1298912), (2378548), (0), (18), (0), (0)'
04:02:45.156  Trace  XXXXXXX  Ml_SoCoSrv_Z11  GCTI-43-30201  [Agent++] SubAgentXMib: PING response received (sid)(tid)(pid)(uptime): (1), (1298912), (2378548), (92178567)
04:02:45.156 ### LOCAL MESSAGE#=30201, '[Agent++] SubAgentXMib: PING response received (sid)(tid)(pid)(uptime): (1), (1298912), (2378548), (92178567)'
04:02:45.367 xxxxx.xx.xxx.com: REventAppLiveStatusChanged... APP_STATUS_STOPPED, mode=EXITED, app=Er_ORS_Tomcat_N11, PID=14384
04:02:45.368 [gsnmpalib]: Managed server status changed 'Er_ORS_Tomcat_N11' dbid = 887 sd = -1: status = APP_STATUS_STOPPED.
04:02:45.368 'xxxxx.xx.xxx.com': NotifyApp: status= APP_STATUS_STOPPED mode=EXITED pid=14384 {887, Er_ORS_Tomcat_N11}
04:02:45.368  Standard  xxxxx.xx.xxx.com  Er_ORS_Tomcat_N11  GCTI-00-05064  Application terminated due to internal condition
04:02:45.368 ### LOCAL MESSAGE#=5064, 'Application terminated due to internal condition'
04:02:45.368 CREATE ActiveAlarm  <107, Application terminated> for  App=<887, Er_ORS_Tomcat_N11>, createTime=1502330565 under control=1
04:02:45.368  Trace  XXXXXXX  Ml_SoCoSrv_Z11  GCTI-43-10612  Active Alarm 'Application terminated' created for Application 'Er_ORS_Tomcat_N11'
04:02:45.368 ### LOCAL MESSAGE#=10612, 'Active Alarm 'Application terminated' created for Application 'Er_ORS_Tomcat_N11' '
04:02:45.368  Alarm  XXXXXXX  Er_ORS_Tomcat_N11  GCTI-00-04115  Application terminated, alarm condition(107)
04:02:45.368 ### LOCAL MESSAGE#=4115, 'Application terminated, alarm condition(107)'
04:02:45.368  Alarm  XXXXXXX  Er_ORS_Tomcat_N11  GCTI-00-04200  Active Alarm "Application terminated" Created (ID=003830D8-BEC5-198B-BDFD-3CB5150AAA77)
04:02:45.368 ### LOCAL MESSAGE#=4200, 'Active Alarm "Application terminated" Created (ID=003830D8-BEC5-198B-BDFD-3CB5150AAA77)'
04:02:45.368 ActiveAlarm::SetDeleteTimer  <107, Application terminated> for App=<887, Er_ORS_Tomcat_N11>, LastSetTime=1502330565, timeout=86400
04:02:45.368 Found Condition <107, Application terminated>, Detect Message = 5064
04:02:45.368 !Execute all Reaction for AlarmCondition <107, Application terminated>
04:02:45.368  Trace  XXXXXXX  Ml_SoCoSrv_Z11  GCTI-43-10500  Reaction 'SNMP_Send_SNMP_Trap' activated
04:02:45.368 ### LOCAL MESSAGE#=10500, 'Reaction 'SNMP_Send_SNMP_Trap' activated'
04:02:45.368 #### App{887,Er_ORS_Tomcat_N11} status changed to APP_STATUS_STOPPED mode=EXITED, [prev=APP_STATUS_RUNNING]
04:02:45.368  Trace  XXXXXXX  Ml_SoCoSrv_Z11  GCTI-43-20620  [Application Er_ORS_Tomcat_N11]: LiveStatus changed to APP_STATUS_STOPPED from APP_STATUS_RUNNING
04:02:45.368 ### LOCAL MESSAGE#=20620, '[Application Er_ORS_Tomcat_N11]: LiveStatus changed to APP_STATUS_STOPPED from APP_STATUS_RUNNING'
04:02:45.368 Check RunMode for {'Er_ORS_Tomcat_N11', EXITED, APP_STATUS_STOPPED}
04:02:45.368 No check for ThirdPartyServer supported
04:02:45.368 XXXXXXX: REventAppLiveStatusChanged... APP_STATUS_RUNNING, mode=PRIMARY, app=Er_ORS_Tomcat_N11, PID=26393
04:02:45.368 [gsnmpalib]: Managed server status changed 'Er_ORS_Tomcat_N11' dbid = 887 sd = -1: status = APP_STATUS_RUNNING.
04:02:45.368  Trace  XXXXXXX  Ml_SoCoSrv_Z11  GCTI-43-30101  [SNMP Sub Agent] Cannot establish management connection with application Er_ORS_Tomcat_N11. Application does not provide for management support.
04:02:45.368 ### LOCAL MESSAGE#=30101, '[SNMP Sub Agent] Cannot establish management connection with application Er_ORS_Tomcat_N11. Application does not provide for management support.'
04:02:45.368 'XXXXXXX': NotifyApp: status= APP_STATUS_RUNNING mode=PRIMARY pid=26393 {887, Er_ORS_Tomcat_N11}
04:02:45.368  Standard  XXXXXXX  Er_ORS_Tomcat_N11  GCTI-00-05060  Application started
Re: Er_ORS_Tomcat Application terminated due to internal condition
« Reply #1 on: August 11, 2017, 11:36:10 AM »
[font=Verdana][size=2px]Application does not provide for management support.[/size][/font]
[font=Verdana][/size][/font]
[font=Verdana][/size][size=2px]Says it all...Tomcat is a 3rd party app[/size][/font]
Offline C_Genesys
« Reply #2 on: August 15, 2017, 06:36:48 AM »
Not getting above reply
