" /> Folder Permissions report? - Genesys CTI User Forum
Author Topic: Folder Permissions report?  (Read 1368 times)
Offline PFCCWA
« on: August 16, 2017, 02:42:30 PM »
Does anyone know if it is possible to report on security or folder permissions ? I want to know what permissions a specific user has for any folder in cme.
I am using business objects and have access to the config server tables.
All the common tables are available but cannot see an obvious one for folder permissions themselves.
thanks,
Wasim
Offline Tambo
Re: Folder Permissions report?
« Reply #1 on: August 17, 2017, 10:48:04 AM »
i think you would need to use the CFG_FOLDER table and use OWNER_TYPE column and ref that against CFG_APP_RANK which gives each agents rank (administrator / super_administrator)
