" /> SIP AoC Feature: how to compose the XML body - Genesys CTI User Forum
Author Topic: SIP AoC Feature: how to compose the XML body  (Read 3101 times)
Offline zzglain
« on: September 28, 2017, 04:02:55 PM »
I have managed to generate a SIP INFO message starting from a RequestPrivateService for the Advice of Charge functionality, but I cannot find useful information on what to insert in the Body MIME part of the SIP message? Does anyone has experience on this?
Regards
Giovanni
Offline terry
Re: SIP AoC Feature: how to compose the XML body
« Reply #1 on: September 29, 2017, 11:08:33 PM »
Cannot say that have experience with that but in IRD in Macro sections there is predefined macro RequestPrivateService_AOC.
Probably some info can be taken from looking at it.
Offline genesysguru
    • Genesys Guru Blog
« Reply #2 on: September 30, 2017, 04:39:32 PM »
Vague memories of this here:
http://genesysguru.com/blog/blog/2013/11/17/sending-a-sip-info-message-from-a-genesys-ird-strategy/
Offline zzglain
« Reply #3 on: October 06, 2017, 01:10:47 PM »
Cannot find the macro pointed out by Terry in my IRD, which version are you using?
I saw the post on genesysguru (which was extremely helpful, thanks) but as Body part it sets up varData=998000000000
I tried using this but the IMS is giving me back an error "Unuspported Media Type", so I think that this body part cannot be applicable in my scenario.
Offline terry
« Reply #4 on: October 07, 2017, 04:41:22 AM »
In regards of IRD - 8.1.4 (8.1.400.22)
But basically it is looks like
Parameters:
AOC_destination_DN,immediateChangeOfActuallyAppliedTariff,delayUntilStart,addOnChargePulse,networkIdentification,referenceID
Definition:
# Prepare XML body for AOC (insert parameters into XML template)
Always -> Push[StrFormat['<messageType xsi:schemaLocation="http://uri.etsi.org/ngn/params/xml/simservs/sci myxsd.xsd" xmlns="http://uri.etsi.org/ngn/params/xml/simservs/sci" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><aocrg><chargingControlIndicators><immediateChangeOfActuallyAppliedTariff>~s</immediateChangeOfActuallyAppliedTariff><delayUntilStart>~s</delayUntilStart></chargingControlIndicators><addOnCharge><addOnChargePulse>~s</addOnChargePulse></addOnCharge><originationIdentification><networkIdentification>~s</networkIdentification><referenceID>~s</referenceID></originationIdentification></aocrg></messageType>',immediateChangeOfActuallyAppliedTariff,delayUntilStart,addOnChargePulse,networkIdentification,referenceID]]
# Prepare Extension for Private Service message
AOC_destination_DN!='' -> Push[StrFormat['extensions.AOC destination DN:~s|extensions.Content-Type:application/vnd.esti.sci+xml|extensions.Content-Disposition:render ; handling=optional|extensions.Body:~s',AOC_destination_DN,Pop[]]]
AOC_destination_DN=''  -> Push[StrFormat['extensions.Content-Type:application/vnd.esti.sci+xml|extensions.Content-Disposition:render ; handling=optional|extensions.Body:~s',Pop[]]]
#Send request
Always -> SendRequest[149, StrFormat['thisdn:~s|connid:~s|105:3018|~s',Dest[],ConnID[],Pop[]]]
« Last Edit: October 07, 2017, 04:45:20 AM by terry »
Offline zzglain
« Reply #5 on: October 11, 2017, 12:21:51 PM »
Thanks Terry,
I installed the version suggested and found the macro.
Thanks for your kind help!
Best regards
Giovanni
