" /> ccilib log - Genesys CTI User Forum
Author Topic: ccilib log  (Read 2110 times)
Offline soporte_sd
ccilib log
« on: October 25, 2017, 03:32:44 PM »
In my Genesys platform I have an unique ccilib log of 2Gb and I have two questions:
- How can I do to configure to split this log file to several smaller ccilib log files?
- I need to release disk space. Would it be any issue if I delete this log file? Is the system going to create a new one?
Best regards,
Re: ccilib log
« Reply #1 on: October 25, 2017, 04:05:34 PM »
???  No clue what is that...where did you find this file?
Can you show some lines of its content?
Offline hsujdik
Re: ccilib log
« Reply #2 on: October 25, 2017, 05:37:03 PM »
It is on the same folder as MCP logs if I remember correctly. I never knew what they are used for, too :(
Re: ccilib log
« Reply #3 on: October 25, 2017, 06:17:16 PM »
Cclib then, right?
I think is the Genesys layer they added to MCP, and works while starting the services.
However mines are like 5Kb as much each.
Offline soporte_sd
Re: ccilib log
« Reply #4 on: October 26, 2017, 11:27:59 AM »
It is in the same folder than ctic logs.
In the primary server there are several files with 4 Kb. But in the secondary server I have only one file with 2 Gb.
The log option configuration is the same in both applications.
So, I need to reduce the size of such log file and I do not know how. Any idea?
Do you think it would be save to delete that log file directly?
Thanks!!
Re: ccilib log
« Reply #5 on: October 26, 2017, 06:00:26 PM »
So according to docs, there is a new option on MCP for this.
[log.all]
Check release notes about this.
However, you should kinda look the contents of those files to understand why they are so big
