" /> failed to run Gim_etl Transform Jobs - Genesys CTI User Forum
Author Topic: failed to run Gim_etl Transform Jobs  (Read 3009 times)
Offline hieutx
« on: October 27, 2017, 10:51:46 AM »
Hi all,
Pls help me that problem. I got Fail when run Gim_etl Transform Jobs.In Gim_etl log, i saw errors as follows:
[code]Caused by: com.genesyslab.gim.etl.exceptions.JdbcUniqueConstraintViolationException: executeUpdate; Unique Constraint Violation for SQL [INSERT INTO dbo.TMP_UDH_SESSION_END SELECT TMP_UDH_CUR_MM.CALLID,TMP_UDH_CUR_MM.KEYNAME,TMP_UDH_CUR_MM.KEYVALUE FROM dbo.TMP_UDH_CUR_MM WHERE TMP_UDH_CUR_MM.KEYNAME = 'ChatServerSessionClientLeftAt']; SQLSTATE=23000; error code=2601; DBError=CONSTRAINT_VIOLATION_UNIQUENESS_VIOLATION; Cannot insert duplicate key row in object 'dbo.TMP_UDH_SESSION_END' with unique index 'I_T_UD_SESS_END'. The duplicate key value is (0000CaCXDCT10098).
at com.genesyslab.gim.etl.exceptions.SQLExceptionTranslator.translate(SQLExceptionTranslator.java:41)
at com.genesyslab.gim.etl.exceptions.SQLExceptionTranslator.translate(SQLExceptionTranslator.java:28)
at com.genesyslab.gim.etl.util.jdbc.SQLUtils.executeUpdate(SQLUtils.java:1426)
at com.genesyslab.gim.etl.util.jdbc.SQLUtils.executeUpdate(SQLUtils.java:1484)
at com.genesyslab.gim.etl.util.jdbc.SQLUtils.executeUpdate(SQLUtils.java:1513)
at com.genesyslab.gim.etl.jobs.transform.FillCoreTablesForCurChunk$FillTmpUdHistoryForCurChunk.runStep(FillCoreTablesForCurChunk.java:377)
... 13 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Cannot insert duplicate key row in object 'dbo.TMP_UDH_SESSION_END' with unique index 'I_T_UD_SESS_END'. The duplicate key value is (0000CaCXDCT10098).[/code]
Thanks a lot !
Offline hsujdik
Re: failed to run Gim_etl Transform Jobs
« Reply #1 on: October 27, 2017, 12:47:34 PM »
You will probably need to open a ticket to fix this, since it is not in any Customer Care arcticle nor Release Notes.
The TMP tables are generated during transformation so probably tech support may send you a script to remove the duplicate data.
Genesys will probably ask you to gather GIM ETL logs and run the GETGIMDATA tool for some interaction after analyzing the logs.
I believe that you might get a response from Customer Care faster if you attached the output of this script on the database (assuming that there is any result):
select callid, keyname, changetype, count(1) from gim81.gidb_g_userdata_history_mm where keyname = 'ChatServerSessionClientLeftAt' and changetype <> 1
group by callid, keyname, changetype
having count(1) > 1
Offline hieutx
« Reply #2 on: November 02, 2017, 01:38:39 AM »
Thanks a lot hsujdik, The problem was Gim ETL. Genesys recommended to upgrade to lastest version of GIM  :)>
Offline JavierG123
« Reply #3 on: February 11, 2022, 09:29:06 PM »
I ran the query and then renamed the rows it found with another letter at the end, and it all started working fine!
Thanks a lot!
Offline hsujdik
« Reply #4 on: February 14, 2022, 02:12:32 AM »
Hi, Javier
You shouldn't manually update those records. The query I mentioned above was to help the Genesys Tech Support find the issue that hieutx posted.
