" /> Error while sending outbound email - Genesys CTI User Forum
Author Topic: Error while sending outbound email  (Read 1664 times)
Offline supersaiyanblue
« on: November 08, 2017, 06:45:29 AM »
Hi All,
I am using Office365 for sending and receiving emails. I am using same smtp-client for sending all outbound emails. For some mailboxes it is working fine but for some mailboxes it is not working and throwing below error.
[b]Error- Error during smtp authentication.[/b]
[smtp-client]
cnx-check-idle-time=00:00:30
cnx-max-idle-time=00:05:00
cnx-pool-size=10
connect-timeout=00:05:00
enable-authentication=true
enable-debug=true
password=*************
port=25
protocol-timeout=00:05:00
server=https://outlook.office365.com/EWS/Exchange.asmx
server-type=ews
smtp-connection-security=none
user=************
Re: Error while sending outbound email
« Reply #1 on: November 08, 2017, 08:45:46 AM »
Need to check logs for the root-cause. In case, you enabled debug, you should see communication details between ESJ and EWS server.
