" /> GI2 standard ABD waiting not match with CCP Standard ABD - Genesys CTI User Forum
Author Topic: GI2 standard ABD waiting not match with CCP Standard ABD  (Read 1324 times)
Offline hasitha
« on: March 02, 2018, 08:37:30 AM »
Dear Folks ,
Recently I found my infoview reports data mismatch with CCP real-time stats. Basically Infoview  standard ABD waiitng calls way higher than CCP realtime stats. I do understand , These two applications pull the data from two different data sources. But users expect to match the data at the EOD .
If any idea/Solution on this highly appreciate.
Thank you,
Hasitha
Offline n3vek7
    • ITKB
Re: GI2 standard ABD waiting not match with CCP Standard ABD
« Reply #1 on: March 02, 2018, 03:22:02 PM »
Check your short abandonned settings. In GI2 (GIM), they'll be removed from the abandon count. In CCP, it depends of your Stat Server settings.
