" /> Realtime scheduled callback stats in Pulse - Genesys CTI User Forum
Author Topic: Realtime scheduled callback stats in Pulse  (Read 3276 times)
Offline genesyslearner
« on: April 18, 2018, 11:23:27 AM »
Hi Experts,
We are using Pulse 8.5.1 and our requirement is to see Scheduled Callback stats in the Pulse.
Could anyone please help me with the pointers if real time stats for callbacks scheduled are possible in Pulse? If yes, then how can we configure it?
I guess we have to make some custom KVP's in the stat server options but i am not sure.
Re: Realtime scheduled callback stats in Pulse
« Reply #1 on: April 18, 2018, 12:04:29 PM »
Which values and scenarios do you want to measure?
« Reply #2 on: April 18, 2018, 12:36:16 PM »
Hi Kubig,
We are focusing on a single scenario in which we want to see number of Callbacks scheduled in the Pulse widget. We have GMS configured in our environment.
« Last Edit: April 18, 2018, 12:50:13 PM by genesyslearner »
Offline eugene
« Reply #3 on: April 18, 2018, 10:35:40 PM »
is this premise or cloud solution?  I believe for cloud there are some out of box templates you could use.
For premise, i have a long winded way if you're interested which is by enabling gms callback notification to hit an ORS workflow for you to peg a reporting VQ every time this event occurs
_cbe_on_callback_scheduled
« Reply #4 on: April 23, 2018, 08:57:38 AM »
Hi eugene,
Thanks for your response!
We have a premise solution. I am not able to completely understand the solution you suggested.
Could you please explain a bit more ? It would be a great help.
« Last Edit: April 23, 2018, 12:01:20 PM by genesyslearner »
Offline eugene
« Reply #5 on: April 24, 2018, 04:25:04 AM »
i will draw up a diagram to illustrate the solution for you.  stay tune
Offline eugene
« Reply #6 on: April 24, 2018, 06:44:55 AM »
genesyslearner, you can read up more on this in genesys docs.
hope you're able to view this diagram i quickly slapped together.
https://1drv.ms/u/s!AoKRvMubyZBNl3sxgyr2O7Rf1yj1
« Reply #7 on: April 26, 2018, 09:39:38 AM »
Thanks a lot eugene for the flow diagram. I am trying to get it done.
Offline eugene
« Reply #8 on: April 26, 2018, 03:07:08 PM »
if you need further  help - just reach out and we can connect over a call.
« Reply #9 on: May 14, 2018, 09:56:21 AM »
Hi Eugene,
I tried to get the stats by following the steps as mentioned here:-
https://docs.genesys.com/Documentation/CLBCK/8.5.1/UG/EnableStatusNotifications
Does the stats in Pulse require additional settings or the steps followed from the above link should be sufficient?
Offline eugene
« Reply #10 on: May 18, 2018, 04:21:58 PM »
i messaged you with my contact info - easier to chat over the phone.
Offline macmill
« Reply #11 on: February 20, 2019, 01:02:46 PM »
Hi there,
I am trying to accomplish the same and having issues with the scxml as well, are you able to post the assist me as well? Possibly post the solution here as well, thanks.
