" /> Sip Server and TServer - Genesys CTI User Forum
Author Topic: Sip Server and TServer  (Read 3886 times)
Offline bundes
« on: May 17, 2018, 12:42:10 PM »
I am designing a Genesys solution over an Alcatel environment.
I was running for a CTI less solution, with SipServer and Sip Trunk. It meant that were no csta monitoring of the phones.
But I then found a document (Genesys Application Note - Alcatel OXE R11 with Genesys VPS 8.1.7) that talks about Sipserver coupled with Tserver.
Since then I have a doubt.
Would it be possible to install both ?
TServer allowing to monitor the phones, Sipserver allowing to play annoucments, route calls and recording ?  ???
Thanks for your help ;)
Offline hsujdik
Re: Sip Server and TServer
« Reply #1 on: May 17, 2018, 01:35:14 PM »
Yes, it is possible to do so... Cavagnaro is the master of integrating with OXE. PM him
Offline bundes
« Reply #2 on: May 17, 2018, 01:56:11 PM »
I'll give a try ;)
Offline bundes
« Reply #3 on: May 17, 2018, 03:03:07 PM »
Working on it.
[img width=640 height=348]https://i62.servimg.com/u/f62/18/85/69/70/2018-010.jpg[/img]
I wonder if I would need to use external routing point feature to do so  ???
« Reply #4 on: May 17, 2018, 03:28:34 PM »
Yes, you would need external routing point in case using both T-Server (Alcatel T-Server + SIP)
Offline bundes
« Reply #5 on: May 17, 2018, 03:35:19 PM »
You can use network routing on the same OXE ?
Will it be able to record calls by the way ?
The OXE is able to manage a conf between agent, client and MCP (via its sip trunk)  ???
« Reply #6 on: May 17, 2018, 03:38:42 PM »
SIP cannot act as a T-Server for voice recording as your agents will be registered under OXE T-Server. The rest of services (announcement, routing, IVR, etc.) should be done on SIP server level
Offline bundes
« Reply #7 on: May 17, 2018, 03:48:31 PM »
It means that once the SipServer has reached the external routing point, and then the agent, he is out of the game ? (that's why he can't record anymore ?).
If we use SipServer and OXE, reassure me, you can record  ;D
[img width=640 height=306]https://i62.servimg.com/u/f62/18/85/69/70/2018-011.jpg[/img]
« Reply #8 on: May 18, 2018, 04:22:27 AM »
Hey sorry, I am on vacations hehe
Well, when call is on an OXE RP then you can't call PlayApplication treatment from SIP SERVER as it is another TServer.
So what you do is to route to sip server RP from OXE then you play all your MCP treatments and GVP maybe, later when you need an agent you do a TRoute to an OXE RP and will then send the call to OXE agents via ISCC so you keep all UData alive.
There is a GVP 8 integration guide from Alcatel.
There is very well explained.
Enviado de meu E6633 usando o Tapatalk
Offline bundes
« Reply #9 on: May 18, 2018, 01:38:48 PM »
Hy cavagnaro,
sorry for disturbing your vacation ;)
I understood that it could work like a GVP installation.
I have a question regarding recording but I will open a new thread as it is a new subject ;)
Thanks.
« Reply #10 on: May 18, 2018, 01:42:28 PM »
RTP Will be at OXE phones, with UA protocol, not SIP therefore, MCP is not a supported recorder for OXE in any way.
You need a valid OXE recorder with DR Link or IP DR LINK.
