" /> No Tenant Found - Genesys CTI User Forum
Author Topic: No Tenant Found  (Read 2076 times)
Offline qoternaud
No Tenant Found
« on: May 29, 2018, 08:19:30 AM »
Hello and thanks for the time you'll take to read this,
I'm trying to start my SIP Server but i get an error :
[i]Error : No tenant found for the main application - exiting ...[/i]
i don't understand why this happening because i already started an URS and a Start Server for example, and everything is fine, and i never have had this error for the rest.
If you have any ideas, let me know,
Regards.
Re: No Tenant Found
« Reply #1 on: May 29, 2018, 12:01:57 PM »
So...add a Tenant for the application at configuration
Enviado de meu E6633 usando o Tapatalk
Offline n3vek7
    • ITKB
Re: No Tenant Found
« Reply #2 on: May 29, 2018, 12:05:22 PM »
In the SIP Server application object, do you have a tenant ( named "Environment" ), in the section T-Server ?
Offline qoternaud
Re: No Tenant Found
« Reply #3 on: May 29, 2018, 12:22:18 PM »
Thanks n3vek7, in the T-Server section i only have 4 sections :
- Management Port : x
- Check tenant profile : False
- Compatibility port :
- server-id : <to configure ...>
no Environnement tenant in this section.
Could you specify please cavagnaro ?
In the options of the SIP Server ? Or in the tenant menu ?
Thanks for your answers.
Re: No Tenant Found
« Reply #4 on: May 29, 2018, 12:23:56 PM »
Add a Tenant in the Tenant tab...
Just follow basic instalation guide
Offline n3vek7
    • ITKB
Re: No Tenant Found
« Reply #5 on: May 29, 2018, 12:42:25 PM »
Oh, I provided info for GA, you must be with GAX,than, cavagnaro gave you the answer.
Tenant Tab should do it.
Offline qoternaud
Re: No Tenant Found
« Reply #6 on: May 29, 2018, 12:57:04 PM »
I'm using GA not GAX but yes i'll will try,
[u][b]
SOLVED :[/b][/u]
i was checking T-Server in the option pan and not in the Configuration Pan,
Thanks N3vek
