" /> DB errors - Genesys CTI User Forum
Author Topic: DB errors  (Read 7187 times)
Zygis
DB errors
Can You help me?
I always getting this errors, this sample is, then I wanted to save new strategy to the server.
And I'm getting errors, like this error, than I make new changes in the CM.
Any Idea?
DBClient++ 8 exec sql failure: ORA0001: unique constraint (GENESYS.SYS_C007
69) violated
DbClient 8 reqid: '47225' (sending): sql MSG_ERROR >> 112603 15:15:15:896>
DBClient 8 received: reqid: '47226', sqlcmd: 'insert into cfg_user_property (
object_dbid, object_type, property_name, property_value, subproperty_name, subp
roperty_value, object_csid, part, type_subprop_value) values (468, 12, 'strateg
y', NULL , 'source', '56657273696f6e20303130300d0a23535452415445475920494420526
5736f75726365730d0a23435245415445442042592064656661756c740d0a234352454154454420
41542031302f31312f30302c2030333a333920504d0d0a235550444154454420425920646566617
56c740d0a23555044415445442041542031312f', 0 , 0, 2)' >> 112603 15:15:15:896>
DbClient 8 reqid: '47226' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:352>
DBClient 8 received: reqid: '47227', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '32362f30332c2030333a313420504d0d0a2e5641524941424c4520535
452494e47204c4f43414c205346726f6d0d0a2e5641524941424c4520535452494e47204c4f4341
4c2053546f0d0a2e5641524941424c4520535452494e47204c4f43414c2043616c6c5072696f726
974790d0a2e5641524941424c4520535452494e', 0 , 1, 2)' >> 112603 15:15:16:352>
DbClient 8 reqid: '47227' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:358>
DBClient 8 received: reqid: '47228', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '47204c4f43414c205746726f6d0d0a2e5641524941424c45205354524
94e47204c4f43414c204f776572466c6f770d0a2e5641524941424c4520535452494e47204c4f43
414c20476f546f546172670d0a2e5641524941424c4520535452494e47204c4f43414c2057546f0
d0a2e5641524941424c4520494e544547455220', 0 , 2, 2)' >> 112603 15:15:16:358>
DbClient 8 reqid: '47228' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:364>
DBClient 8 received: reqid: '47229', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '4c4f43414c204157544d696e696d616c0d0a2e5641524941424c45204
94e5445474552204c4f43414c204157544d6178696d616c0d0a2e53544154495354494320537461
744167656e7473546f74616c2031313131313131313131313131313131313131313131313031313
131313131313131313131313131313131313131', 0 , 3, 2)' >> 112603 15:15:16:364>
DbClient 8 reqid: '47229' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:369>
DBClient 8 received: reqid: '47230', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '313131313131313131313131313131313131313131313131313131313
1313131313131313131313131313131313131313131313131313131312031322030203020302030
2031203220303030303030303030303030303030303030303030303030303030303030303030303
030303030303030303030303030303030303030', 0 , 4, 2)' >> 112603 15:15:16:369>
DbClient 8 reqid: '47230' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:374>
DBClient 8 received: reqid: '47231', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030303030303030303030303030303030303030303030303030303
0303030303030303030303030303030303030303020302030203020500d0a2e5354415449535449
4320537461744167656e7473417661696c61626c652030303030313030303030303030303030303
030303030303030303030303030303030303030', 0 , 5, 2)' >> 112603 15:15:16:375>
DbClient 8 reqid: '47231' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:381>
DBClient 8 received: reqid: '47232', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030303030303030302031
3220302030203020302031203220303030303030303030303030303030303030303030303030303
030303030303030303030303030303030303030', 0 , 6, 2)' >> 112603 15:15:16:381>
DbClient 8 reqid: '47232' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:386>
DBClient 8 received: reqid: '47233', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303020302030203020500d0a
2e535441544953544943205374617443616c6c73496e51756575652030303030303030303031303
030303030303030303030303030303030303030', 0 , 7, 2)' >> 112603 15:15:16:387>
DbClient 8 reqid: '47233' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:392>
DBClient 8 received: reqid: '47234', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030303030303030303030
3030303020313220302030203020302030203020303030303030303030303030303030303030303
030303030303030303030303030303030303030', 0 , 8, 2)' >> 112603 15:15:16:392>
DbClient 8 reqid: '47234' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:398>
DBClient 8 received: reqid: '47235', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030303030303020302030
203020520d0a2e535441544953544943205374617443616c6c73436f6d706c65746564203030303
030303030303030303030303030303131313131', 0 , 9, 2)' >> 112603 15:15:16:399>
DbClient 8 reqid: '47235' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:404>
DBClient 8 received: reqid: '47236', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030302031203020302030203020302030203030303030303030303030303
030303030303030303030303030303030303030', 0 , 10, 2)' >> 112603 15:15:16:404>
DbClient 8 reqid: '47236' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:420>
DBClient 8 received: reqid: '47237', sqlcmd: 'insert into cfg_user_property (
30303020302030203020500d0a2e53544154495354494320537461744167656e747342757379203
030303030303030313030303030303030303030', 0 , 11, 2)' >> 112603 15:15:16:420>
DbClient 8 reqid: '47237' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:425>
DBClient 8 received: reqid: '47238', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030302031322030203020302030203020322030303030303030303
030303030303030303030303030303030303030', 0 , 12, 2)' >> 112603 15:15:16:425>
DbClient 8 reqid: '47238' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:434>
DBClient 8 received: reqid: '47239', sqlcmd: 'insert into cfg_user_property (
3030303030303020302030203020500d0a2e535441544953544943205374617454696d65496e526
561647953746174652030303030313030303030', 0 , 13, 2)' >> 112603 15:15:16:436>
DbClient 8 reqid: '47239' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:440>
DBClient 8 received: reqid: '47240', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030303030303030303020313120302030203020302031203
220303030303030303030303030303030303030', 0 , 14, 2)' >> 112603 15:15:16:442>
DbClient 8 reqid: '47240' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:448>
DBClient 8 received: reqid: '47241', sqlcmd: 'insert into cfg_user_property (
303030303030303030303030303030303020302030203020500d0a2e53544154495354494320417
6657261676543616c6c57616974696e6754696d', 0 , 15, 2)' >> 112603 15:15:16:448>
DbClient 8 reqid: '47241' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:453>
DBClient 8 received: reqid: '47242', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '653120303030303030303030313030303030303030303030303030303
3030303030303030303030303030303030303030303030303030303030303030303030303030203
220322030203020363020312030203030303030', 0 , 16, 2)' >> 112603 15:15:16:456>
DbClient 8 reqid: '47242' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:462>
DBClient 8 received: reqid: '47243', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030303130303030303030303030303030303030303030303030303
30303030303030303030303030303030303030303030303030303030303020302030203020510d0
a2e53544154495354494320537461744c6f6164', 0 , 17, 2)' >> 112603 15:15:16:463>
DbClient 8 reqid: '47243' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:468>
DBClient 8 received: reqid: '47244', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '42616c616e63652030303030303030303030303030303030303030303
3030303030303030303030303030303030303030303030303030303030303030303030303030303
030303020333420332030203020353020302030', 0 , 18, 2)' >> 112603 15:15:16:468>
DbClient 8 reqid: '47244' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:474>
DBClient 8 received: reqid: '47245', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '203030303030303030303030303030303030303030303030303030303
3030303030303030303030303030303030303030303030303030303030303030303030302030203
0203020520d0a2e535441544953544943205374', 0 , 19, 2)' >> 112603 15:15:16:474>
DbClient 8 reqid: '47245' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:480>
DBClient 8 received: reqid: '47246', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '617443616c6c73416e737765726564203030303030303030303030303
0303030303030303030303030303130303030303030303030303030303030303030303030303030
030303030303030303030302031203020302030', 0 , 20, 2)' >> 112603 15:15:16:480>
DbClient 8 reqid: '47246' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:491>
DBClient 8 received: reqid: '47247', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '203020302030203030303030303030303030303030303030303030303
0303020302030203020500d0a2e535441544953', 0 , 21, 2)' >> 112603 15:15:16:492>
DbClient 8 reqid: '47247' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:495>
DBClient 8 received: reqid: '47248', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '5449432053746174457870656374656457616974696e6754696d65203
030303030303030303030303030303030303030', 0 , 22, 2)' >> 112603 15:15:16:504>
DbClient 8 reqid: '47248' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:509>
DBClient 8 received: reqid: '47249', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030302033332032203020302036303020302030203030303030303
030303030303030303030303030303030302030', 0 , 23, 2)' >> 112603 15:15:16:511>
DbClient 8 reqid: '47249' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:514>
DBClient 8 received: reqid: '47250', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '2030203020520d0a2e5354415449535449432053746174457374696d6
174656457616974696e6754696d6520303030303030303030313030303030303030303030303030
030303030303030303030303030303030303030', 0 , 24, 2)' >> 112603 15:15:16:516>
DbClient 8 reqid: '47250' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:523>
DBClient 8 received: reqid: '47251', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030303030303030303030303030303030303020313620302030203
0203020302030203030303030303030303030303030303030303030303030303030303030303030
030303030303030303030303030303030303030', 0 , 25, 2)' >> 112603 15:15:16:524>
DbClient 8 reqid: '47251' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:529>
DBClient 8 received: reqid: '47252', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '30303030303030303030303020302030203020520d0a2e53544154495
3544943205374617453657276696365466163746f72203030303030303030303030313030303030
030303030303030303030303030303030303030', 0 , 26, 2)' >> 112603 15:15:16:530>
DbClient 8 reqid: '47252' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:534>
DBClient 8 received: reqid: '47253', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030303030303030303030303030303030303030303030303030203
9203220302030203630302031203020303030303030303030303030303030303030303030303030
030303030303030303030303030303030303030', 0 , 27, 2)' >> 112603 15:15:16:535>
DbClient 8 reqid: '47253' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:543>
DBClient 8 received: reqid: '47254', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '303030303030303030303030303030303030303020302030203020520
d0a2e424c4f434b20424c526f757465546f57510d0a234d61696e2053747261746567790d0a2357
6f726b696e67486f75727320496e74657276616c20666f7220576f726b696e67204461797320616
e64205370656369616c20576f726b696e672044', 0 , 28, 2)' >> 112603 15:15:16:544>
DbClient 8 reqid: '47254' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:550>
DBClient 8 received: reqid: '47255', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '6179730d0a416c77617973202d3e2041737369676e5b5746726f6d2c2
7373a3030275d41737369676e5b57546f2c2732313a3030275d41737369676e5b5346726f6d2c27
383a3030275d41737369676e5b53546f2c2731353a3030275d0d0a235465737420666f7220576f7
26b696e6720486f7572730d0a28204973537065', 0 , 29, 2)' >> 112603 15:15:16:550>
DbClient 8 reqid: '47255' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:559>
DBClient 8 received: reqid: '47256', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '6369616c4461795b275370656369616c576f726b696e6744617973272
c27275d203d2031202620282054696d65203c205346726f6d207c2054696d65203e2053546f2029
297c2849735370656369616c4461795b274672656544617973272c27275d203d203020262028205
4696d65203c205746726f6d207c2054696d6520', 0 , 30, 2)' >> 112603 15:15:16:560>
DbClient 8 reqid: '47256' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:565>
DBClient 8 received: reqid: '47257', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '3e2057546f202920297c2849735370656369616c4461795b274672656
544617973272c27275d3d3129202d3e20546172676574735b27272c4f4f57726b45484440537461
74536572766572353130502e52505d576169745b305d7b7d0d0a23496e6372656173652043616c6
c205072696f726974790d0a416c77617973202d', 0 , 31, 2)' >> 112603 15:15:16:567>
DbClient 8 reqid: '47257' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:570>
DBClient 8 received: reqid: '47258', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '3e2041737369676e5b4f776572466c6f772c27454844275d557064617
4655b274f776572466c6f77272c4f776572466c6f775d5570646174655b274465706172746d656e
74272c4f776572466c6f775d4174746163685b27437573746f6d6572272c27454844275d5570646
174655b27437573746f6d6572272c2745484427', 0 , 32, 2)' >> 112603 15:15:16:571>
DbClient 8 reqid: '47258' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:579>
DBClient 8 received: reqid: '47259', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '5d0d0a416c77617973202d3e2041737369676e5b43616c6c5072696f7
26974792c55446174615b2743616c6c5072696f72697479275d202b203132305d5570646174655b
2743616c6c5072696f72697479272c43616c6c5072696f726974795d5072696f726974795b43616
c6c5072696f726974795d0d0a23526f75746520', 0 , 33, 2)' >> 112603 15:15:16:579>
DbClient 8 reqid: '47259' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:584>
DBClient 8 received: reqid: '47260', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '746f204167656e7447726f75700d0a6568643a416c77617973202d3e2
04576656e5b5374617454696d65496e526561647953746174655d546172676574735b27272c4548
444053746174536572766572353130502e47415d576169745b355d7b7d0d0a234c6f6f6b696e672
0617661696c61626c65206167656e7420696e20', 0 , 34, 2)' >> 112603 15:15:16:586>
DbClient 8 reqid: '47260' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:589>
DBClient 8 received: reqid: '47261', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '6f74686572207369746520284b6c616970656461290d0a53446174615
b31313740537461745365727665723531304b2e47412c537461744167656e7473417661696c6162
6c655d3e3d312653446174615b56515f31313740537461745365727665723531304b2e512c53746
17443616c6c73496e51756575655d3d30202d3e', 0 , 35, 2)' >> 112603 15:15:16:590>
DbClient 8 reqid: '47261' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:594>
DBClient 8 received: reqid: '47262', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '20546172676574735b27272c3131375f4f55544053746174536572766
572353130502e52505d576169745b305d7b7d0d0a23526f7574652043616c6c7320546f20427573
79206966204177657261676520576169746e6754696d652069732062696765720d0a53446174615
b56515f45784844405374617453657276657235', 0 , 36, 2)' >> 112603 15:15:16:594>
DbClient 8 reqid: '47262' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:598>
DBClient 8 received: reqid: '47263', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '3130502e512c4176657261676543616c6c57616974696e6754696d653
15d3e393030202d3e20546172676574735b27272c546f4275737940537461745365727665723531
30502e52505d576169745b305d7b7d0d0a23526f7574696e672043616c6c7320546f204d6573736
1676520526f7574696e6720506f72740d0a416c', 0 , 37, 2)' >> 112603 15:15:16:598>
DbClient 8 reqid: '47263' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:602>
DBClient 8 received: reqid: '47264', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '77617973202d3e20546172676574735b27272c457848444d657373405
3746174536572766572353130502e52505d576169745b305d7b7d0d0a424c526f757465546f5751
3a0d0a53446174615b5669727475616c517565756540537461745365727665725f50412e512c417
6657261676543616c6c57616974696e6754696d', 0 , 38, 2)' >> 112603 15:15:16:603>
DbClient 8 reqid: '47264' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:612>
DBClient 8 received: reqid: '47265', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '65315d203e3d204157544d696e696d616c20262053446174615b56697
27475616c517565756540537461745365727665725f50412e512c4176657261676543616c6c5761
6974696e6754696d65315d203c204157544d6178696d616c202d3e20546172676574735b27272c4
76f546f546172675d576169745b305d7b7d0d0a', 0 , 39, 2)' >> 112603 15:15:16:612>
DbClient 8 reqid: '47265' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:617>
DBClient 8 received: reqid: '47266', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'source', '235b4352435d20323038373237310d0a', 0 , 40, 2)' >> 112603
15:15:16:617>
DbClient 8 reqid: '47266' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:623>
DBClient 8 received: reqid: '47267', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '47574243312e3030c4200000a303000028020000600000000005005
346726f6d030000030053546f0300000c0043616c6c5072696f7269747903000005005746726f6d
03000008004f776572466c6f770300000800476f546f54617267030000030057546f0300000a004
157544d696e696d616c0200000a004157544d6178', 0 , 0, 2)' >> 112603 15:15:16:626>
DbClient 8 reqid: '47267' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:652>
DBClient 8 received: reqid: '47268', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '696d616c0200020c00536574537461746973746963010f005374617
44167656e7473546f74616c030f00537461744167656e7473546f74616c011b002e537472696e67
436f6e7374537461744167656e7473546f74616c030f00537461744167656e7473546f74616c01f
2002e537472696e67436f6e737431313131313131', 0 , 1, 2)' >> 112603 15:15:16:652>
DbClient 8 reqid: '47268' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:658>
DBClient 8 received: reqid: '47269', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3131313131313131313131313131313130313131313131313131313
1313131313131313131313131313131313131313131313131313131313131313131313131313131
3131313131313131313131313131313131313131313131313131313131203132203020302030203
02031203220303030303030303030303030303030', 0 , 2, 2)' >> 112603 15:15:16:658>
DbClient 8 reqid: '47269' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:663>
DBClient 8 received: reqid: '47270', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030303030303030303030303
303030303030303030303030303030303030303030203020302030205003e600313131313131313
13131313131313131313131313131313031313131', 0 , 3, 2)' >> 112603 15:15:16:663>
DbClient 8 reqid: '47270' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:670>
DBClient 8 received: reqid: '47271', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3131313131313131313131313131313131313131313131313131313
3131313131313131203132203020302030203020312032203030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 4, 2)' >> 112603 15:15:16:672>
DbClient 8 reqid: '47271' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:675>
DBClient 8 received: reqid: '47272', sqlcmd: 'insert into cfg_user_property (
2030203020302050011300537461744167656e7473417661696c61626c650313005374617441676
56e7473417661696c61626c65011f002e53747269', 0 , 5, 2)' >> 112603 15:15:16:675>
DbClient 8 reqid: '47272' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:683>
DBClient 8 received: reqid: '47273', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '6e67436f6e7374537461744167656e7473417661696c61626c65031
300537461744167656e7473417661696c61626c6501f2002e537472696e67436f6e737430303030
3130303030303030303030303030303030303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 6, 2)' >> 112603 15:15:16:686>
DbClient 8 reqid: '47273' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:690>
DBClient 8 received: reqid: '47274', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303020313220302030203020302031203220303030303030303030303030
03030303030303030303030303030303030303030', 0 , 7, 2)' >> 112603 15:15:16:690>
DbClient 8 reqid: '47274' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:695>
DBClient 8 received: reqid: '47275', sqlcmd: 'insert into cfg_user_property (
0303030203020302030205003e60030303030313030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 8, 2)' >> 112603 15:15:16:695>
DbClient 8 reqid: '47275' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:702>
DBClient 8 received: reqid: '47276', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030302031322030203020302
0302031203220303030303030303030303030303030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 9, 2)' >> 112603 15:15:16:702>
DbClient 8 reqid: '47276' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:707>
DBClient 8 received: reqid: '47277', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303020302030203020500110005374617443616
c6c73496e51756575650310005374617443616c6c73496e5175657565011c002e537472696e6743
6f6e73745374617443616c6c73496e51756575650310005374617443616c6c73496e51756575650
1f2002e537472696e67436f6e7374303030303030', 0 , 10, 2)' >> 112603 15:15:16:708>
DbClient 8 reqid: '47277' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:712>
DBClient 8 received: reqid: '47278', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303130303030303030303030303030303030303030303030303
3030303030303030303030303030303030303030303030303030303030302031322030203020302
03020302030203030303030303030303030303030', 0 , 11, 2)' >> 112603 15:15:16:713>
DbClient 8 reqid: '47278' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:717>
DBClient 8 received: reqid: '47279', sqlcmd: 'insert into cfg_user_property (
30303030303030303030303030303030303030303030203020302030205203e6003030303030303
03030313030303030303030303030303030303030', 0 , 12, 2)' >> 112603 15:15:16:718>
DbClient 8 reqid: '47279' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:723>
DBClient 8 received: reqid: '47280', sqlcmd: 'insert into cfg_user_property (
3030303030303030302031322030203020302030203020302030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 13, 2)' >> 112603 15:15:16:723>
DbClient 8 reqid: '47280' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:729>
DBClient 8 received: reqid: '47281', sqlcmd: 'insert into cfg_user_property (
3020302030203020520112005374617443616c6c73436f6d706c657465640312005374617443616
c6c73436f6d706c65746564011e002e537472696e', 0 , 14, 2)' >> 112603 15:15:16:729>
DbClient 8 reqid: '47281' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:733>
DBClient 8 received: reqid: '47282', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '67436f6e73745374617443616c6c73436f6d706c657465640312005
374617443616c6c73436f6d706c6574656401f1002e537472696e67436f6e737430303030303030
3030303030303030303030313131313130303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 15, 2)' >> 112603 15:15:16:734>
DbClient 8 reqid: '47282' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:740>
DBClient 8 received: reqid: '47283', sqlcmd: 'insert into cfg_user_property (
0303030303030303020312030203020302030203020302030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 16, 2)' >> 112603 15:15:16:740>
DbClient 8 reqid: '47283' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:764>
DBClient 8 received: reqid: '47284', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030303030303030303030302
03020302030205003e5003030303030303030303030303030303030303131313131303030303030
03030303030303030303030303030303030303030', 0 , 17, 2)' >> 112603 15:15:16:764>
DbClient 8 reqid: '47284' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:770>
DBClient 8 received: reqid: '47285', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030203120302030203020302030203
0203030303030303030303030303030303030303030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 18, 2)' >> 112603 15:15:16:772>
DbClient 8 reqid: '47285' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:776>
DBClient 8 received: reqid: '47286', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '30303030302030203020302050010e00537461744167656e7473427
57379030e00537461744167656e747342757379011a002e537472696e67436f6e73745374617441
67656e747342757379030e00537461744167656e74734275737901f2002e537472696e67436f6e7
37430303030303030303130303030303030303030', 0 , 19, 2)' >> 112603 15:15:16:777>
DbClient 8 reqid: '47286' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:781>
DBClient 8 received: reqid: '47287', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030203132203020302030203020302032203030303030303
03030303030303030303030303030303030303030', 0 , 20, 2)' >> 112603 15:15:16:782>
DbClient 8 reqid: '47287' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:792>
DBClient 8 received: reqid: '47288', sqlcmd: 'insert into cfg_user_property (
303030303030303030203020302030205003e600303030303030303031303030303030303030303
03030303030303030303030303030303030303030', 0 , 21, 2)' >> 112603 15:15:16:792>
DbClient 8 reqid: '47288' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:797>
DBClient 8 received: reqid: '47289', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030303030303020313220
3020302030203020302032203030303030303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 22, 2)' >> 112603 15:15:16:798>
DbClient 8 reqid: '47289' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:806>
DBClient 8 received: reqid: '47290', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030203020302030205001140053
74617454696d65496e526561647953746174650314005374617454696d65496e526561647953746
174650120002e537472696e67436f6e7374537461', 0 , 23, 2)' >> 112603 15:15:16:809>
DbClient 8 reqid: '47290' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:813>
DBClient 8 received: reqid: '47291', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '7454696d65496e526561647953746174650314005374617454696d6
5496e5265616479537461746501f2002e537472696e67436f6e7374303030303130303030303030
03030303030303030303030303030303030303030', 0 , 24, 2)' >> 112603 15:15:16:813>
DbClient 8 reqid: '47291' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:818>
DBClient 8 received: reqid: '47292', sqlcmd: 'insert into cfg_user_property (
0303030203131203020302030203020312032203030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 25, 2)' >> 112603 15:15:16:818>
DbClient 8 reqid: '47292' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:861>
DBClient 8 received: reqid: '47293', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030303030303030203020302
030205003e600303030303130303030303030303030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 26, 2)' >> 112603 15:15:16:862>
DbClient 8 reqid: '47293' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:866>
DBClient 8 received: reqid: '47294', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303020313120302030203020302031203220303
03030303030303030303030303030303030303030', 0 , 27, 2)' >> 112603 15:15:16:866>
DbClient 8 reqid: '47294' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:872>
DBClient 8 received: reqid: '47295', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '303020302030203020500117004176657261676543616c6c5761697
4696e6754696d65310317004176657261676543616c6c57616974696e6754696d65310123002e53
7472696e67436f6e73744176657261676543616c6c57616974696e6754696d65310317004176657
261676543616c6c57616974696e6754696d653101', 0 , 28, 2)' >> 112603 15:15:16:873>
DbClient 8 reqid: '47295' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:878>
DBClient 8 received: reqid: '47296', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', 'f2002e537472696e67436f6e7374303030303030303030313030303
03030303030303030303020322032203020302036', 0 , 29, 2)' >> 112603 15:15:16:879>
DbClient 8 reqid: '47296' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:882>
DBClient 8 received: reqid: '47297', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3020312030203030303030303030303130303030303030303030303
03030203020302030205103e60030303030303030', 0 , 30, 2)' >> 112603 15:15:16:883>
DbClient 8 reqid: '47297' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:890>
DBClient 8 received: reqid: '47298', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030313030303030303030303030303030303030303030303030303
3030303030303030303030303030303030303030303030303030303030203220322030203020363
02031203020303030303030303030313030303030', 0 , 31, 2)' >> 112603 15:15:16:891>
DbClient 8 reqid: '47298' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:895>
DBClient 8 received: reqid: '47299', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030303030302030203020302051010f00537461744c6f616
442616c616e6365030f00537461744c6f61644261', 0 , 32, 2)' >> 112603 15:15:16:898>
DbClient 8 reqid: '47299' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:901>
DBClient 8 received: reqid: '47300', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '6c616e6365011b002e537472696e67436f6e7374537461744c6f616
442616c616e6365030f00537461744c6f616442616c616e636501f3002e537472696e67436f6e73
7430303030303030303030303030303030303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 33, 2)' >> 112603 15:15:16:903>
DbClient 8 reqid: '47300' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:906>
DBClient 8 received: reqid: '47301', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030302033342033203020302035302030203020303030303030
03030303030303030303030303030303030303030', 0 , 34, 2)' >> 112603 15:15:16:907>
DbClient 8 reqid: '47301' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:911>
DBClient 8 received: reqid: '47302', sqlcmd: 'insert into cfg_user_property (
0303030303030303030203020302030205203e70030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 35, 2)' >> 112603 15:15:16:911>
DbClient 8 reqid: '47302' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:916>
DBClient 8 received: reqid: '47303', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030303030303030302033342
0332030203020353020302030203030303030303030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 36, 2)' >> 112603 15:15:16:917>
DbClient 8 reqid: '47303' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:922>
DBClient 8 received: reqid: '47304', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030203020302030205201110
05374617443616c6c73416e7377657265640311005374617443616c6c73416e737765726564011d
002e537472696e67436f6e73745374617443616c6c73416e7377657265640311005374617443616
c6c73416e73776572656401f1002e537472696e67', 0 , 37, 2)' >> 112603 15:15:16:922>
DbClient 8 reqid: '47304' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:927>
DBClient 8 received: reqid: '47305', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '436f6e7374303030303030303030303030303030303030303030303
0303030313030303030303030303030303030303030303030303030303030303030303030303030
03020312030203020302030203020302030303030', 0 , 38, 2)' >> 112603 15:15:16:927>
DbClient 8 reqid: '47305' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:932>
DBClient 8 received: reqid: '47306', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030303030303030303030303030303030203020302030205
003e5003030303030303030303030303030303030', 0 , 39, 2)' >> 112603 15:15:16:933>
DbClient 8 reqid: '47306' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:937>
DBClient 8 received: reqid: '47307', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303130303030303030303030303030303030303
3030303030303030303030303030303030303020312030203020302030203020302030303030303
03030303030303030303030303030303030303030', 0 , 40, 2)' >> 112603 15:15:16:938>
DbClient 8 reqid: '47307' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:951>
DBClient 8 received: reqid: '47308', sqlcmd: 'insert into cfg_user_property (
30303030303030303030203020302030205001170053746174457870656374656457616974696e6
754696d6503170053746174457870656374656457', 0 , 41, 2)' >> 112603 15:15:16:952>
DbClient 8 reqid: '47308' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:956>
DBClient 8 received: reqid: '47309', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '616974696e6754696d650123002e537472696e67436f6e737453746
174457870656374656457616974696e6754696d6503170053746174457870656374656457616974
696e6754696d6501f4002e537472696e67436f6e737430303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 42, 2)' >> 112603 15:15:16:956>
DbClient 8 reqid: '47309' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:959>
DBClient 8 received: reqid: '47310', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030303030303030302033
3320322030203020363030203020302030303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 43, 2)' >> 112603 15:15:16:960>
DbClient 8 reqid: '47310' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:964>
DBClient 8 received: reqid: '47311', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030303030303030303030303030302030203020302052
03e8003030303030303030303030303030303030303030303030303030303030303030303030303
03030303030303030303030303030303030303030', 0 , 44, 2)' >> 112603 15:15:16:965>
DbClient 8 reqid: '47311' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:969>
DBClient 8 received: reqid: '47312', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030303030303030203333203220302030203630302030203020303030
03030303030303030303030303030303030303030', 0 , 45, 2)' >> 112603 15:15:16:970>
DbClient 8 reqid: '47312' (sending): MSG_SQLEXECUTED >> 112603 15:15:16:999>
DBClient 8 received: reqid: '47313', sqlcmd: 'insert into cfg_user_property (
0303030303030303030303030203020302030205201180053746174457374696d61746564576169
74696e6754696d6503180053746174457374696d6174656457616974696e6754696d650124002e5
37472696e67436f6e737453746174457374696d61', 0 , 46, 2)' >> 112603 15:15:16:2>
DbClient 8 reqid: '47313' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:6>
DBClient 8 received: reqid: '47314', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '74656457616974696e6754696d6503180053746174457374696d617
4656457616974696e6754696d6501f2002e537472696e67436f6e73743030303030303030303130
03030303030303030303030303030303030303030', 0 , 47, 2)' >> 112603 15:15:17:7>
DbClient 8 reqid: '47314' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:11>
DBClient 8 received: reqid: '47315', sqlcmd: 'insert into cfg_user_property (
0303030302031362030203020302030203020302030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 48, 2)' >> 112603 15:15:17:12>
DbClient 8 reqid: '47315' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:37>
DBClient 8 received: reqid: '47316', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030303030303030303030303030302030203
02030205203e6003030303030303030303130303030303030303030303030303030303030303030
03030303030303030303030303030303030303030', 0 , 49, 2)' >> 112603 15:15:17:37>
DbClient 8 reqid: '47316' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:44>
DBClient 8 received: reqid: '47317', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030303030303030303030203136203020302030203020302030203
03030303030303030303030303030303030303030', 0 , 50, 2)' >> 112603 15:15:17:47>
DbClient 8 reqid: '47317' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:51>
DBClient 8 received: reqid: '47318', sqlcmd: 'insert into cfg_user_property (
y', NULL , 'bytecode', '3030302030203020302052011100537461745365727669636546616
3746f720311005374617453657276696365466163746f72011d002e537472696e67436f6e737453
74617453657276696365466163746f720311005374617453657276696365466163746f7201f3002
e537472696e67436f6e7374303030303030303030', 0 , 51, 2)' >> 112603 15:15:17:53>
DbClient 8 reqid: '47318' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:58>
DBClient 8 received: reqid: '47319', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030303030303030303030302039203220302030203630302
03120302030303030303030303030303030303030', 0 , 52, 2)' >> 112603 15:15:17:58>
DbClient 8 reqid: '47319' (sending): MSG_SQLEXECUTED >> 112603 15:15:17:63>
DBClient 8 received: reqid: '47320', sqlcmd: 'insert into cfg_user_property (
3030303030303030303030303030303030303030203020302030205203e70030303030303030303
03030313030303030303030303030303030303030', 0 , 53, 2)' >> 112603 15:15:17:63>
DbClient 8 reqid: '47320' (sending): MSG_SQLEXECU
Superglide
DB errors
Has the strategy you are trying to save been given a real name? I think the the "NULL" means no name given to the strategy.
Marked as best answer by on Today at 12:55:14 AM
DB errors
  • Undo Best Answer
  • Wow... it looks like ... you did not run the proper script when you have initialized your CME. I know it sounds ridiculous, but from the look of things, you do not have primary keys defined for your table. Did you always have this problem, or only recently?
    Is it a production or lab environment?
    Zygis
    DB errors
    Hallo,
    Yes, I'm having this errors always, if I want create new agents, example two agents, one agent i can create, second not, in the log i always getting this error:
    96) violated.
    CME show this messages:
    Data Communication Manager Error Message
    Error message: SCEE005 the link to the Configuration is not available. Contact Your network administrator.
    Last Action: add
    Object Type: unknown Object
    Object property: unknown.
    And:
    Error message: SCEE006 A database error has occured. Try the same transaction again. If the problem persists, contact your network administrator.
    Last Action: add
    And after that, Ihave go to DB and delete object, and then I can create new objects.
    DB errors
    Hahahahaha!!!! I think I got it!
    jeez, poor guy! You are really messed up!
    I don't know how you got there, but I am pretty sure that you will need to play with the values in cfg_max table (<- or something like that). This is where Genesys holds all the last maximum unique key used. So, open up that table, and just increase the value there to some arbitrary number above the one you already have in the tables.
    I have no clue how you got there, because it happened to me only because I was actually messing with CME tables... Of course, I do recall that unless I ran all THREE scripts when installing CME, I would get a similar error.
    How did you install CME? Manually or did you use a wizard?
