" /> Create Alarm condition: outbound campaign status - Genesys CTI User Forum
Author Topic: Create Alarm condition: outbound campaign status  (Read 1915 times)
Offline ducth
« on: June 10, 2018, 04:02:17 PM »
Hi Guy,
I want to receive alarm by email when outbound campaign change status (Load/unload, Start/Stop).
How can I do it?
Re: Create Alarm condition: outbound campaign status
« Reply #1 on: June 20, 2018, 09:13:28 PM »
There are several ways to do it, with setting it in SCI (Genesys Administrator) would be the easiest way; however, I am not a fan of it. The reason is that by relying on Genesys for system monitoring, I am fragmenting my system monitoring infrastructure: network, servers, DBs, clients, OS, clouds are all monitored by one sysmon and Genesys by another? To me this makes little sense.
If you do want to save a little bit of money and time on Genesys, then look at Message Server logs: it tells you quite  a lot. I found it much easier to just run the grep on the log files and execute a script from it.
tail -f /path/to/serverLog | awk '/Genesys campaign is on fire!/ { system("shutdown -h now") }
                                  /new Campaign started/ { system("echo New Campaign Started" | mail admin")'
I am a bit more fan of this because I found it cheaper to migrate non-essential functions of Genesys to third-party.
If you have a sysmon software (as any call center should), you can just track MIB.
« Reply #2 on: June 20, 2018, 10:25:08 PM »
Forgot to mention to add the KVP at the routing strategy with key = "DC_GW_FULL" and value="[font=verdana][size=0px]Genesys campaign is on fire![/size][/font]"  >:D
« Reply #3 on: June 22, 2018, 01:08:47 AM »
Brilliant!
But jokes aside, look into a log-based solution or a SNMP. It should give ou all the info you need.
