" /> Genesys license and CUCM Extension Mobility - Genesys CTI User Forum
Author Topic: Genesys license and CUCM Extension Mobility  (Read 2271 times)
Offline Leonxxx86
« on: June 19, 2018, 06:17:50 AM »
Hi, how does the Genesys license works with Cisco Extension Mobility? so the licence manager, tserver sdn is 180 but I have more than 300 exts in Genesys. how does that work? thanks
Re: Genesys license and CUCM Extension Mobility
« Reply #1 on: June 19, 2018, 01:18:33 PM »
In SIP world license is consumed when a register event arrives. License is freed when an Out of Service event arrives.
So when your cisco extension goes live (register) Genesys will know about it too and monitor it by consuming a license. Of course you can only monitor up to 180 extensions at same time. The 181 may work at Cisco but Genesys will reject it's register event
Enviado de meu E6633 usando o Tapatalk
Offline Leonxxx86
« Reply #2 on: June 19, 2018, 11:13:17 PM »
Thanks Cav, but the 300 exts are working in both Cisco and Genesys, I'm thinking this is to do with Extension Mobility and Genesys licenses but can't understand how.
« Reply #3 on: June 19, 2018, 11:26:31 PM »
Can't be...check your sip server logs about licensing
Offline Leonxxx86
« Reply #4 on: June 20, 2018, 01:09:23 AM »
Thanks Cav
Offline Genesys_LM
« Reply #5 on: June 22, 2018, 09:36:25 AM »
With the latest SIP version, the default licensing is set to 1 purchased seat: 1 tserver_sdn ratio. CUCM Extension Mobility will not require additional tserver_sdn
If you are still on 8.1 (8.1 used to require double tserver_sdn for CUCM) you need to upgrade to the latest version.  If for some reason you can't upgrade, please submit the official AFR request, explain a reason for the additional licensing. Genesys licensing will review your request with PM
