" /> X-Genesys- makes Trunk gw call fail - Genesys CTI User Forum
Author Topic: X-Genesys- makes Trunk gw call fail  (Read 2868 times)
« on: July 13, 2018, 09:57:20 PM »
Hi guys
I have a problem with a carrier, when I call to GVP using it, the SIP Server attaches the X-Genesys headers to the SDP at the OK message, but seems the length of this KVPs are a problem for them
Is there a way to tell SIP Server not to send them to the Trunk?
Offline vmc
Re: X-Genesys- makes Trunk gw call fail
« Reply #1 on: July 14, 2018, 08:13:59 AM »
SIP trunk from carrier into SIP Server to GVP?  Cube, SBC?  What message do you get when it fails?
Sent from my Redmi Note 3 using Tapatalk
« Reply #2 on: July 14, 2018, 02:43:24 PM »
Trunk to carrier.
What happens is that the carrier doesn't send an ACK after the 200 from Invite
Yes, we have a SBC in the middle but problem comes from the Carrier
Enviado de meu E6633 usando o Tapatalk
« Last Edit: July 14, 2018, 02:46:01 PM by cavagnaro »
Offline hsujdik
« Reply #3 on: July 14, 2018, 03:37:48 PM »
Try setting the sip-proxy-headers-enabled to false on that trunk. I know it works for generated messages, but I’m not sure it will have the same effect on replies
« Reply #4 on: July 14, 2018, 03:50:42 PM »
Will test it
« Reply #5 on: July 15, 2018, 07:52:35 PM »
Yay! It works! Thanks
