" /> Conference Scenario - Genesys CTI User Forum
Author Topic: Conference Scenario  (Read 3943 times)
Offline gen_den
Conference Scenario
« on: July 16, 2018, 04:49:52 PM »
HI Experts,
is it possible that for an GMS callback outbound call, when call is connected between agent and customer i can somehow conference in IVR and let IVR be silent till the time agent and customer are on call. And as soon as agent disconnects the call, control is taken over by IVR for survey??
Offline hsujdik
Re: Conference Scenario
« Reply #1 on: July 16, 2018, 05:19:29 PM »
Check if the Routing Pont option “after-call-divert-destination” suits your needs.
(Note: although the manual says it only supports inbound calls on the option description, I have seen it working for outbound calls as long as they don't have CPD involved).
« Last Edit: July 16, 2018, 06:06:58 PM by hsujdik »
Offline gen_den
« Reply #2 on: July 17, 2018, 04:52:56 AM »
Thank you for the response, but this feature works only with Inbound call. Its not applicable for OUtbound call :(
Marked as best answer by ankush87 on July 19, 2018, 04:27:18 PM
« Reply #3 on: July 18, 2018, 05:38:25 PM »
Maybe you can send call first to the GVP application and then do a conference with the agent, later when agent releases call the GVP remains in control.
« Reply #4 on: July 18, 2018, 06:12:31 PM »
How GVP do conference
https://docs.genesys.com/Documentation/GVP/85/GDG/HGWMPC#MWC
Offline gen_den
« Reply #5 on: July 19, 2018, 03:27:43 AM »
Thanks Cav will check the documentation and try this approach
