" /> CallBack Queue Question - Genesys CTI User Forum
Author Topic: CallBack Queue Question  (Read 1509 times)
Offline schut1mj
« on: October 16, 2018, 05:38:19 PM »
We are reporting our callbacks within a queue summary report, when we pull the report, Accept Service Level % is populating for those calls that were completed within the callback process (out queues).  What parameters are used to determine whether or not a callback call meets service level?  When looking at the SQL, it shows that it's calculated against the ACCEPTED_THR, is there a platform setting like q-answer-threshold-voice that applies to out queues?
Offline hsujdik
Re: CallBack Queue Question
« Reply #1 on: October 17, 2018, 02:16:04 AM »
I don’t really understood if this is what you need, but you can configure the option q-answer-threshold-voice at  VirtualQueue-level. Just create a section called gim-etl at its annex and insert that option and the value that you want.
