" /> Call Transfer Failure - Genesys CTI User Forum
Author Topic: Call Transfer Failure  (Read 1449 times)
Offline GOOGLE IT
« on: October 19, 2018, 02:41:32 PM »
Hello Folks,
Expected Call Flow: Client --->800#(SIP TRUNCK) -->PSTN--->ATT SBC--->Avaya Session Manager--->GVP --->IVR Played and determines the DN--->that DN is Configured in SIP and routing strategy is loaded-->hits that Strategy where Trouting to another DN(Defined in Avaya Switch--->Avaya switch adjunct route to the T-Server --->URS routes to that to available Agent.
** SINGLE SITE ONLY**
Problem: Event Error is noticed in URS Logs at the T-Route step where we have seen Invalid Called DN. Seen the same in SIP visualizer logs.
Any thoughts on this will be helpful.
Re: Call Transfer Failure
« Reply #1 on: October 19, 2018, 05:21:37 PM »
Connecting...
Prii ring ring tra tra...modem sounds....
Connected...
Accessing with default credentials....fail
Pass genesys@123....go
fine....
Accessing logs
Aham...yeah...cool...yep...whut? Ah ok....
I see...
Checking Trunk...ahhhh
Ok problem is at your PBX
:D
Offline GOOGLE IT
« Reply #2 on: November 02, 2018, 02:17:16 PM »
Thanks for responding. I knew with out logs it is really hard to troubleshoot but I am in a scenario where I could not upload any logs. After going through the SIP server logs I fixed the problem by adding the ERP in our Avaya Session Manager which then resolved the cross site transfers.
« Reply #3 on: November 02, 2018, 05:15:08 PM »
Thanks for sharing the solution
