" /> ORS Scxml - Genesys CTI User Forum
Author Topic: ORS Scxml  (Read 2320 times)
Offline genesyslearner
ORS Scxml
« on: December 21, 2018, 11:25:23 AM »
Hi Experts,
I am facing a problem with scxml execution. I have made a simple Integrated Voice & route straegy where i have used three blocks namely:- Enter,Target Group ,Exit. When i assign this published strategy to a Routing Point and then call that Routing point ,ORS logs gives me below errors:-
16:30:55.079 Std 22101 [T:3404] ORS FM ixn: Validation error for extension <redirect>
16:30:55.109 Std 23005 ORS SCXML Session Create failed for session 9L0QVSUM8D3994615CD0VI7TE800000L reason: Validation exception Unknown attribute: detach at line 2726
16:30:55.109 Alr 23015 Orchestration session: 9L0QVSUM8D3994615CD0VI7TE800000L create failed for reason: Validation exception Unknown attribute: detach at line 2726
URS logs are as below:-
16:30:52.987_T_I_008102d161dc2016 [14:0c] EventRouteRequest is received for ts SIP_Server_New[SIP_Switch] (thisdn=9002)
    _T_I_008102d161dc2016 [14:09] add DN SIP_Server_New 9002 <9002@SIP_Switch> (CDN 71 008102d161dc2016 0000000002003d60) to the call 2348-0000000001ff8508 truly:111
    _T_I_008102d161dc2016 [14:08] check delayed proc
    _T_I_008102d161dc2016 [14:43] call data updated
    _I_I_008102d161dc2016 [09:0e] script 0000000000f79088 DS 0000000002003d38 [4] +r (0 0) (14 0000000000000000)
    _I_I_ [25:01] script **ORS usage +1=1
    _I_I_008102d161dc2016 [14:33] strategy: **ORS (1085200831) is attached to the call
16:30:53.050 Int 20001 interaction 008102d161dc2016 is started
    _I_I_008102d161dc2016 [01:14] current call classification: media=voice(100), service=default(200), segment=default(300)
16:30:53.085_I_I_008102d161dc2016 [09:06] >>>>>>>>>>>>start interp()
    _I_I_008102d161dc2016 [09:04] ASSIGN: Name(SCRIPT) <- STRING[3,11]: "ScxmlServer"
    _I_I_008102d161dc2016 [09:0e] script 0000000000f7e608 DS 00000000020031e8 [97] +r (93 14) (14 0000000000000000)
    _I_I_ [25:01] script **ScxmlServer usage +1=1
16:30:53.629_I_I_008102d161dc2016 [07:48] func will be continued(0,0000000031a00018)
16:30:53.629_I_I_008102d161dc2016 [09:04] <<<<<<<<<<<<suspend interp(JUMPING), func:CallStrategy timers:00001
@@@1545390053.630147<-43(643064) !!!
16:30:53.630_I_I_008102d161dc2016 [07:49] func is continued(0,0000000031a00018)
    _I_I_008102d161dc2016 [07:43] call strategy **ScxmlServer (level=2, crc=4167199099)
    _I_I_008102d161dc2016 [09:06] SCXML: init session SID=4UB1AD2NQL5LFFD522KCCQI1R800001F, doc=ScxmlServer
16:30:53.630_I_I_008102d161dc2016 [09:06] >>>>>>>>>>>>start interp()
    _I_I_008102d161dc2016 [07:46] no error mode for this call
    _I_I_008102d161dc2016 [09:04] ASSIGN: v:0:this(LOCAL) <- OBJECT:0000000000F633D8[Global]={"Class":"Global"}
    _I_I_008102d161dc2016 [09:04] ASSIGN: v:0:_genesys(LOCAL) <- OBJECT:0000000002005D38[Object]={}
    _I_I_008102d161dc2016 [09:06] <<<<<<<<<<<<stop interp
    _I_I_008102d161dc2016 [09:06] SCXML: session SID=4UB1AD2NQL5LFFD522KCCQI1R800001F initialized
16:30:53.641_I_I_008102d161dc2016 [1c:06] SCXML: {{{{{start session SID=4UB1AD2NQL5LFFD522KCCQI1R800001F
    _I_I_008102d161dc2016 [1c:06] 1. SCXML: look for transitions (1)
    _I_I_008102d161dc2016 [1c:05] 2. SCXML: microstep
    _I_I_008102d161dc2016 [1c:05] 2.1 SCXML: microstep exitting phase
    _I_I_008102d161dc2016 [1c:05] 2.2 SCXML: microstep transiting phase
    _I_I_008102d161dc2016 [1c:05] 2.3 SCXML: microstep entering phase
    _L_I_008102d161dc2016 [1c:03] SCXML: entering state <initial>
16:30:53.641_I_I_008102d161dc2016 [09:08] >>>>>>>>>>>>start interp(f:0:_d_1_initial)
    _I_I_008102d161dc2016 [09:04] ASSIGN: p:25:this(LOCAL) <- OBJECT:0000000000F633D8[Global]={"Class":"Global"}
16:30:53.642_I_I_008102d161dc2016 [09:04] <<<<<<<<<<<<suspend interp(NONE), func:SCXMLGetEvent timers:00000
    _I_I_008102d161dc2016 [1c:06] 1. SCXML: look for transitions (2)
16:30:53.642_I_I_008102d161dc2016 [1c:06] SCXML: }}}}}suspend session SID=4UB1AD2NQL5LFFD522KCCQI1R800001F
16:30:53.642_Z_I_ [0B:02] Exception is received for message server Message_Server
16:30:53.642 Std 04502 Cannot connect to MessageServer 'Message_Server' at host 'WIN-BB02I3I3R01', port 1113, reason 'cancel'
16:30:53.642_G_I_ [0B:04] server Message_Server is being closed, socket 544
16:30:53.642_G_I_ [0F:08] SERVER Message_Server(0000000001fffe10 0 1 1) tried: 0 0000000001fffe10 0000000001fffe10
received from 70968(SIP_Server_New)WIN-BB02I3I3R01:5100(fd=) message EventAttachedDataChanged
AttributeCallType 1
AttributePropagatedCallType 1
AttributeCallID 22
AttributeConnID 008102d161dc2016
AttributeCallUUID '027P7UC9JD55J1F0RGHMDREV8400000M'
AttributeUserData [154] 00 01 03 00..
'ORSI:cluster:027P7UC9JD55J1F0RGHMDREV8400000M'(list) 'Session' '9L0QVSUM8D3994615CD0VI7TE800000L+'
                                                      'Node' '137'
                                                      'Url' 'http://WIN-BB02I3I3R01:1118/scxml'
AttributeDNIS '9002'
AttributeThisDN '9002'
AttributeThisDNRole 2
AttributeThirdPartyDN '1002'
AttributeTimeinSecs 1545390053 (16:30:53)
AttributeTimeinuSecs 831000
AttributeEventSequenceNumber 0000000000000302
Any help on the error will be great for my learning.
Marked as best answer by genesyslearner on December 28, 2018, 01:52:02 AM
Offline eugene
Re: ORS Scxml
« Reply #1 on: December 22, 2018, 02:09:12 AM »
Hard to tell without seeing your actual scxml but I highly suspect it is the syntax of your target block.
Double check to make sure you’re referencing what’s described in the composer help guide for the object you’re targeting.
Re: ORS Scxml
« Reply #2 on: December 27, 2018, 11:54:12 AM »
Thanks eugene for your quick knowledge share. Target block was causing the error, however when i made routing logic with reference from Composer help guide,it worked.
