" /> Short Calls - Genesys CTI User Forum
Author Topic: Short Calls  (Read 3630 times)
Fabio
Short Calls
I have to calculate short inbound calls on virtual queue. Is it possible?
I have no ptoblem to calculate the same thing on Agent or Agent group like in this example:
Category=TotalNumberInTimeRange
Objects=Agent, GroupAgents, GroupPlaces, Place
MainMask=CallInbound
Subject=DNAction
Description=Total number of inbound calls in Time range for Agent
thanks.
Jeff K.
Short Calls
  • What is a "short" call?
    I thought "short" call was a call that was dropped before being answered!
    TotalNumberInTimeRange would give you number of times calls has appeared at agent's station.
    tenshi
    Short Calls
  • fabio, try adding
    GroupQueues, Queue
    to the Objects part of your stat.
    Tony Tillyer
    Short Calls
  • Fabio,
    "Short Calls", as Jeff states, are normally associated with Agent ype stats. A VQ is a pass hrough point, applied to any RP, Queue or passout point in a Strategy, etc.
    I'm not sure if you want to try and calculate the timings for a dropped call through the VQ or the time to a Short Abandoned Call to an Agent?
    What's the plan/idea/brief?
    Tony
