" /> What is the best Handle Time - Genesys CTI User Forum
Author Topic: What is the best Handle Time  (Read 1778 times)
Offline PFCCWA
« on: February 12, 2019, 08:04:18 PM »
I am interested in knowing what is used for handle time at the moment?
I know there is no correct way as it could be dependent on the end user requirements.
We are using :
[b](time) inbound+consult+hold+dialing+outbound+internal+outbound
(number) inbound+internal+outbound[/b]
there is no in-call status split between inbound,outbound and internal so these are always included. We also have cases where the agents make outbound calls and may perform consult.
thanks,
Re: What is the best Handle Time
« Reply #1 on: February 12, 2019, 08:53:41 PM »
Handle Time is Business dedicated time for a customer interaction.
So Inbound/Outbound+ACW Status Time
If you are doing a division then guess you want Average Time?
In your division why you also don't add up consult+hold?? If you are measuring Status then add them too...
Internal...that is not business related usually as it was a private call or without customer
Offline vmc
« Reply #2 on: February 13, 2019, 09:33:27 AM »
Definitely include acw. I wouldn't necessarily count number of hold statuses in the divided by section though as you may skew your figures where one call had multiple holds etc.
Sent from my Redmi Note 3 using Tapatalk
