" /> GA displaying objects - Genesys CTI User Forum
Author Topic: GA displaying objects  (Read 1496 times)
Offline MunichMax
« on: March 01, 2019, 01:02:19 PM »
Hi guys,
At the moment we're using the Genesys Administrator 8.1.308.02 version and our customer asked to view more users at once than 100.
if there is any possibility to increase the displaying object number?
Thanks in advance
Offline G.Line
Re: GA displaying objects
« Reply #1 on: March 01, 2019, 01:33:02 PM »
Assuming you're displaying your results in pulse, you can set this value in the options of the Collector.  Here you're able to adjust # of object and statistics in the Layout.
Hope this helps,
G.Line
Offline MunichMax
« Reply #2 on: March 01, 2019, 02:12:07 PM »
Sorry if the question was not clear. I'm don't asking about Pulse, i mean directly when you choose "Accounts -> Users" at the Navigation panel on Genesys Administrator.
Offline msd86911
« Reply #3 on: March 05, 2019, 01:15:31 PM »
Hi MunichMax,
You don't have to be sorry, You question was clear enough.
All GA options are listed with description in file <InstallDir>\resources\metadata\Genesys_Administrator_Current.xml and can be adjusted in default application under options.
But I couldn't find anything related to number or records per page.
Maybe there is a hidden option that I don't know about.
