" /> How to get AgentID(Statistics notready) - Genesys CTI User Forum
Author Topic: How to get AgentID(Statistics notready)  (Read 1560 times)
Offline soyoung
« on: March 18, 2019, 03:00:04 AM »
i can get to Agent ID as Ready.
1.AgentDN = MultiSkill(Server, Skill)
2.AgentID = SelectDN(Queue,'','StatAgentLoading',AgentDN)
3.KVListGetStringValue(AgentID,'agent')
i want to get Agent ID when Statistics change into Ready from NotReady. too
Why is it that I can't acquire it when Agent's Statistics change into the Ready from NotReady or Afterwork??? ??? ???
or Can i use to Udata[RTargetAgentSelected]?
« Last Edit: March 18, 2019, 05:57:00 AM by soyoung »
Offline terry
Re: How to get AgentID(Statistics notready)
« Reply #1 on: March 18, 2019, 04:04:26 AM »
It is router and its major task return/find agent ready to process the interaction - which among other things assumes that agent is in ready state.
You can use statistical functions like TargetState to get current status of agent - ready, on call, ACW, etc. if it is what you  want.
And if it is about tracking exact  moments when agent state is changed  - knowing usecase what it needed for  might help.
Offline soyoung
« Reply #2 on: March 18, 2019, 04:15:50 AM »
i I've solved it
but, i cant solve as recall..! ???
i used Udata[KVPname]
Is means i can't get to Agent ID?
Can I get to Agent ID ready state only?
I can get to Agent ID as ready state at IRD 8.1
but, if Agent state is notready, Call is waiting call.
and, i change into ready as Agent State.
Agent id is null...
i think because i geted to SelectDN(Queue,'',[b]'StatAgentLoading'[/b],AgentDN)
« Last Edit: March 18, 2019, 08:56:33 AM by soyoung »
