" /> How to check VoiceXML version (GVP 7.2) - Genesys CTI User Forum
Author Topic: How to check VoiceXML version (GVP 7.2)  (Read 1787 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: June 19, 2019, 08:26:22 AM »
Hi all, hope everything's fine out there; as in object, I would like to know wich VoiceXML version is installed.
Best regards,
Gef.
« Last Edit: June 19, 2019, 10:10:16 AM by Gef Buneri »
Re: How to check VoiceXML version (GVP 7.2)
« Reply #1 on: June 19, 2019, 11:33:32 AM »
What do you mean by installed? VXML is an standard as HTML for example. Each version has its own attributes which makes them compatible or not according to the VXML browser.
What are you exactly after?
Enviado de meu SM-G9650 usando o Tapatalk
Offline Gef Buneri
« Reply #2 on: June 19, 2019, 11:42:18 AM »
Hi Cav; a third party vendor asked us wich version of VoiceXML GVP supports. Reading Genesys documentation about VXML, I read informations about compatibility with specific versions (W3 2.1, Telera 2.0, Genesys 2.0), but informations refers to GVP 7.6, not to 7.2, so I would like to know if specifications are the same for gvp 7.2 too.
« Reply #3 on: June 19, 2019, 11:44:05 AM »
Ah no, gvp 7.6 engine was different. Even another product.
Geee 7.2 is hard to find docs about it. Will see if have any.
Check at installation folder, remember there were some docs installed along with it
Offline Gef Buneri
« Reply #4 on: June 19, 2019, 11:57:31 AM »
Searched, but only reference i find is inside some url declaration in vxml.dll; something like 'telera 2.0', 'Genesys 2.0', W3 1.0, but not sure if this infos can be reliable.
« Reply #5 on: June 19, 2019, 01:47:19 PM »
Well Google is your friend
Found these:
https://voicexml.org/certification-programs/voicexml-platform-certification-program/
https://voicexml.org/certification-programs/voicexml-platform-certification-program/voicexml-2-0-certified-platforms/
http://www.contactcenterarchitects.com/gvp-genesys-voice-portal/
Also found the Deployment guide for the Studio and states:
[quote]Genesys Voice Platform 7.2 VoiceXML 2.1 Reference Manual, which
provides information about developing VoiceXML 2.1 applications on
GVP. It presents VoiceXML 2.1 concepts and provides examples that focus
on the GVP implementation of VoiceXML. It also describes the platform
extensions to VoiceXML that Genesys provides. [/quote]
Offline Gef Buneri
« Reply #6 on: June 21, 2019, 02:35:35 PM »
Thanks a lot, Cav. Dunno if it's due sorta regional restriction, but can't find in google the doc "Genesys Voice Platform 7.2 VoiceXML2.1 Reference Manual"; if it will happen you to find a direct link, I ask you if you could share.
« Last Edit: June 21, 2019, 02:40:48 PM by Gef Buneri »
